I hope it makes sense and will be of use to someone.
PS. How do I do a screen shot ?
regds
Gordon
I know I willFeckless wrote:I'll see if I can borrow the original and take some pics, I belive when ye see it that many of ye will make one.
looks like 3/8" to me.jdh239 wrote:how thick of plate did you cut it out of?
Rollable thickness will decrease with added width.762frmafr wrote:Yes, a picture of the cranking method would be greatly appreciated, also, how wide could you make this? Could you make it so that you could roll a 24" piece of steel? Also, how thick of material will this roll? Thank you. Steve
So is 10ga by 3 feet long possible with a setup like this?nalin400m wrote:Rollable thickness will decrease with added width.762frmafr wrote:Yes, a picture of the cranking method would be greatly appreciated, also, how wide could you make this? Could you make it so that you could roll a 24" piece of steel? Also, how thick of material will this roll? Thank you. Steve
This is just a guess, but I think you would not be able to do that with this machine. You would need something much more heavy duty. I am hoping this would be sufficient for 20" of 16 gauge, but I don't even know if that is pushing it.762frmafr wrote:So is 10ga by 3 feet long possible with a setup like this?nalin400m wrote:Rollable thickness will decrease with added width.762frmafr wrote:Yes, a picture of the cranking method would be greatly appreciated, also, how wide could you make this? Could you make it so that you could roll a 24" piece of steel? Also, how thick of material will this roll? Thank you. Steve
