Can someone help
Can someone help
I have been trying to draw so file in plasmacam and would like to know if this file looks cut worthy or not...If someone can give me their opinion I would appreciate it. Thanks.
- AnotherDano
Re: Can someone help
That's some good stuff, Woodman.
You're going to lose the 18 on the flag, most likely. Too small to cut.
And, you might want to make sure the wolf's eye isn't too close to the edge, with a test cut on a scrap part of the sheet.
And the name will need some bridging to hold onto the dropouts. I'd be tempted to reverse the image on the name. There is a lot of material on the bottom and lower right. Making the characters 'positive' would lighten that up. But that's just a personal preference of mine.
I really like that!
Dano
I really like that!
Dano
Dano Roberts
droberts@ironpequod.com
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
- erichsmith
If you could send it in an ACAD DXF file 2004 or older i'll take a look at it as well.
Eric Smith
Hobart Champion
Miller ABP330
Miller 185, 212
Miller Spectrum 625
Miller Dialarc 250
Oxy/Fuel
MSC Mill
Atlas Lathe
Grizzly Mill/Lathe
Scars and 1 understanding wife, 1 uninterested 16yr old girl, 1 thinks daddys work is cool 3yr old son.
Hobart Champion
Miller ABP330
Miller 185, 212
Miller Spectrum 625
Miller Dialarc 250
Oxy/Fuel
MSC Mill
Atlas Lathe
Grizzly Mill/Lathe
erichsmith wrote:If you could send it in an ACAD DXF file 2004 or older i'll take a look at it as well.
Ok Eric I will try but I think my program is newer than '04....But thanks for the support...This is a great website with lots of giving posters
Nice file & I agree with above comments. I also opened the file in PlasmaCam. One problem I found was it detected 789 intersections. Select your image then at the top in Pcam select "Machine" then "Detect Intersections" & see what you get. It needs to be zero before cutting. If it detects intersections then select the image then select "Edit" then "Link Segments". Now select "Detect Intersections" again and it should read zero. This has to be done before converting the image to cut paths otherwise it will show your lead ins as intersections. Keep us posted on how it goes.
Danny
Danny
- FreeDXF.com
The PCM file looked fairly good from the start. The lettering needed a little work as well as the 18 on the flag. I did some quick redesign work and am attaching the revised PCM file. This should cut a little better for you. JH
- plasmajoe
Can you post it as a DXF? I cannot open PCM files.
Here you go Plasmajoe
Thanks everyone for the much needed help...I will post a pic as soon as its cut out and let you know how it goes......Thanks again everyone!!!
Thats a cool sign! Thanks for sharing!
