Tiltrotator mini excavator
MorastCNC
Post by MorastCNC »
This is the beginning of project tiltrotator for my mini excavator
Very nice cuts with Hypertherm PM65
/Bj?rn
BensPlasmaAu
Re: Project in the beginning
Post by BensPlasmaAu »
Keep posting pictures Bjorn, I'm keen to see how this goes.
Home built 3400 x 1400mm (11 and a bit X a bit over 4.5 feet)
Hypertherm Powermax 45
CandCNC Bladerunner IV
Some air dryer off the internet
Another water seperator I found unused on a shelf
Refrigerated air dryer
MorastCNC
Re: Tiltrotator mini excavator
Post by MorastCNC »
More pictures
beefy
Post by beefy »
Hi Bjorn,
I hope too you can show some more pics as you manufacture it. Did you cut the worm gear set yourself. If so what metal did you use and did you get it hardened afterwards (self or hardening shop). Is that a geroller / gerotor type motor (low speed high torque), nothing will stop that gear wheel from turning LOL
I've got a little digger too, made a grab and a rake for mine.
Good luck with your project, love to see more,
Keith
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
MorastCNC
Post by MorastCNC »
Hi Keith
Both the worm gear and the motor is from a Ramsey winch
I'll try to get a smaller motor in the future, this motor is only for try to see if everything
is working as I have planned
/Bj?rn
hanix
Post by hanix »
This is my mini excavator rotor made from forklift rotator.
Se also
http://www.plasmaspider.com/viewtopic.php?f=3&t=12968
Hanix
MorastCNC
Post by MorastCNC »
Hi Hanix
The rotor looks nice!
Seems that you have cut some details :D
/Bj?rn
MorastCNC
Post by MorastCNC »
The box
MorastCNC
Re: Project in the beginning tiltrotator mini excavator
Post by MorastCNC »
The gearbox completed
Next challenge will be the plates for the tilt
Think I must do some lineboring after welding
pipeliner
Post by pipeliner »
Excellent work !!! Love the root rake also.
MorastCNC
Post by MorastCNC »
More details
MorastCNC
Post by MorastCNC »
Little closer to first testrun
hanix
Post by hanix »
This is great, keep posting on this project and more pictures.
How are you going to control this?
I disconnected the hydraulic jack that was used to extending the track frame and connect it to the rotor motor.
And discontented the horn button and, I am going to use that to control the tilt jack.
Hanix
skofla smiduð leiðrétt.dxf
(278.63 KiB) Downloaded 166 times
MorastCNC
Post by MorastCNC »
The control of rotor will be with a 6/2 valve on the boom swing
/Bj?rn
MorastCNC
Post by MorastCNC »
Waiting for tiltcylinder
MorastCNC
Post by MorastCNC »
More details
MorastCNC
Post by MorastCNC »
Now it's very close to first testrun
I have to mount a 6/2 valve for the boom swing
and a crossover valve to reduce the pressure for the hydraulic motor
B Holmes
Post by B Holmes »
Great project! Thanks for taking the time to post all the pictures.
5 x 10 Air bladder water table
Precision plasma HDB gantry
CandCnC 620-4 Bladerunner
Feather touch ohmic plate sensing
Hypertherm Powermax 65
2015 Autocad lt
Mach 3
Central California
quadboy
Post by quadboy »
Nice work, I like how you mounted the tilt cylinder.
MorastCNC
Post by MorastCNC »
First testrun
http://youtu.be/6abl7qCBYSc
It works great, but something have to be adjusted in the hydraulic circuit
It takes 180 bar to move the rotor, I have mountet a 6/2 valve on the boom swing and it
takes 180 bar to move the boom swing to.
So I think there is some flow reduction somewhere,but I can't find it.
East German
Post by East German »
Well done good work
Regards Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
hanix
Post by hanix »
Hey Bj?rn haw you figured the hydraulic problem out ?
Hanix
illusivedf
Post by illusivedf »
Cool Project
Owner at Illusive Design & Fabrications
http://www.illusivefabrications.com
Air Ride Suspension Parts
Metal Fabrication
Dynatorch 4x8 with Hypertherm 1250
Vinyl Decals & Signs
Powder Coating
MorastCNC
Post by MorastCNC »
Hi Hanix
I finally solved the hydraulic problem
It is a loadholdning valve for the boom sving in the main valve
So what I have to do was switching the functions so the tilt now is operated
with the boom sving valve.
Now it works, but a little problem is to learn to operate the tilt with the left switch instead
of the right switch, but I think practice will solve the problem
Here how it works:
http://youtu.be/peTQkcSnq88
Some pictures of the bucket I made
Bj?rn
East German
exquisite work
congratulations
Regards Peter
MyPlasmCNC
Machine Torch
Machine Torch
