And thanks again to Jason (MetalTorcher). I know basically nothing about the cutting process so Jason goes over my files to make sure they're ready to cut. Thanks Jason
I'm posting two versions of this file. The first version is scaled up so there should be little to no issues for plasma. The problem is though, this version will eat up a 4x8 sheet.
The second version is scaled down to 36" in height and can possibly be used as a railing insert.
Awhile back I was in touch Allan, (OTHill) and talking about railing inserts and we both had the same concerns, simply of someone getting a finger or hand caught in the cutout . . . a very real concern.
We spoke of the possibility of closing in one side with Plexiglas, but also concluded that Plexiglas was not a cheap solution. So I guess it boils down to what a customer wants to spend. Or does someone else have a solution to this?
If someone does cut this out, I'd REALLY appreciate if you could post a picture.
NOTICE
Jason found a small issue with the original Horsemen file, so he fixed it and we're re-posting the file.
Tom
