Vertical bender using JD2 dies
Re: Vertical bender using JD2 dies
That's exactly what i was looking for. would you mind posting those files of the square tube dies? please and thanks
Sure, why not.cypher wrote:That's exactly what i was looking for. would you mind posting those files of the square tube dies? please and thanks
There is no follower die, I just used the normal 7/8" pin and let the square tube rest against it.
No problems,Thank you! I might not use it, I'm between this and just buying the Rogue Fab
Square tube is all that I can make at my shop, No mill to cut out the center section, they all worked good for that, thanks KHHas anybody bent square tubing on this ?
Jim
5x10 Flow Waterjet
Ilean,
I noticed on your bender you have 2 springs is that needed or will one work?
Jim
Jim
One will work fine. I went with too light of a spring originally, so I had to double them up.james.davis wrote:Ilean,
Jim
Jim
Jim
http://www.plasmaspider.com/download/fi ... w&id=41443
Ilean,
Sorry to bug you some much but are these holes close on your file or did I screw up when I copied it.
The holes are about an 1/8" away from each other.Will it matter?
Jim
Ilean,
Jim
I can't see your file...but there are some holes that are pretty close to each other for sure. That's how they are on the JD2 drawing I started with.
Thanks, going to mod to fit my pt105
Gary
Gary
If you already have a PT105, you can just bolt the existing bender into the lower/base part to make it into a vertical bender, if you want to do that. I have done that a couple times, so I can post that file if you want to that direction.
Sure thanks, Are the pin holes in a different location?
Sorry, missed this! What I meant was just the brackets to mount the existing Pro Tools bender vertically. This is the file I've used a couple times to do that.mmw wrote:Sure thanks, Are the pin holes in a different location?
Hello, I cut this file out over 5 Years ago for a friend that passed away and got back the vertical uprights. He wasn't able to finish it. I wanna finish it but no longer have the word doc that has the dimensions for the base.
Can anyone share the lengths of of the 3x3 tubing?
Thanks, I finally got my plasma cutter back online after moving and getting back into into things.
Not sure if this is what you need, thanks KH
5x10 Flow Waterjet
I'm not a member atm so I don't open that. If I remember correctly it was 2 pcs at 18" and 2 at 24" but wanna make sure before I cut my tubing. I know it doesn't have to be exact I just want to know because you it's what obviously works
Double posted.
Tubing for base: 3x3 square; Two 12” lengths, two 24” lengths.
5x10 Flow Waterjet
Thank you!
Has anyone made one of the square dies yet ? The dxf file doesn't seem to have the center of the die needed to dent the tubing .
Arclight 4x4
Hypertherm Pm45
Lincoln 256 Mig
Precision Tig 275
Baileigh 50 Ton Press
Quincy 2 stage 5Hp compressor
Hypertherm Pm45
Lincoln 256 Mig
Precision Tig 275
Figured it out .... Thanks
Arclight 4x4
Hypertherm Pm45
Lincoln 256 Mig
Precision Tig 275
Hypertherm Pm45
Lincoln 256 Mig
Precision Tig 275
I can’t seem to get access to the bender dxf file at the beginning post
I’m a paying member
There something I’m missing
I’m a paying member
I don't know why you can't download the files, but I do think it's awesome this thread is still trickling along after 5 years.
Can this be used with model 3 dies that's all I can get
Yes, it's designed for use with Model 3 die sets.
fantasic going to give it a cut in next few weeks
