Vertical bender using JD2 dies
Legend199
Re: Vertical bender using JD2 dies
Post by Legend199 »
I need file for tubing bender j.d..square
Legend199
Post by Legend199 »
I paid for file never got it
I Lean
Post by I Lean »
The files are linked in the very first post of this thread, you can download them there.
Legend199
Post by Legend199 »
I paid for file can't download them they screw me
Legend199
Post by Legend199 »
redheadfred wrote:Figured it out .... Thanks
How do u download dfx file for vertical tubing bender jd2..
Legend199
Post by Legend199 »
Prototypetom wrote:fantasic going to give it a cut in next few weeks
How did u get off file I can't get it
Legend199
Post by Legend199 »
How did u get dfx file I can't get it
nalin400m
Post by nalin400m »
Legend199 wrote:I paid for file can't download them they screw me
Take a chill pill. All the files in this thread are still downloadable.
Nalin Manufacturing, LLC
Hypertherm Powermax 85
Bulltear Starlab 4'x8'
:lol: Chill pill
Legend199
Post by Legend199 »
mav68erick wrote:Hello, I cut this file out over 5 Years ago for a friend that passed away and got back the vertical uprights. He wasn't able to finish it. I wanna finish it but no longer have the word doc that has the dimensions for the base.
Can anyone share the lengths of of the 3x3 tubing?
Thanks, I finally got my plasma cutter back online after moving and getting back into into things.
2 24in and 2 12 in 3x3
Legend199
Post by Legend199 »
tjenus wrote:Not sure if this is what you need, thanks KH
Parts list for completing vertical bender.docx
What spaces and bolts go where I can't figure it out
Legend199
Post by Legend199 »
I Lean wrote:
james.davis wrote:Ilean,
I noticed on your bender you have 2 springs is that needed or will one work?
Jim
One will work fine. I went with too light of a spring originally, so I had to double them up.
U have pic of how bender goes together with spacers I can't get it 704-273-6194
Legend199
Post by Legend199 »
How do the spacers go on the vertical tubing bender and how wide does the base need to be I can't get where spacers and bolts go
Legend199
Post by Legend199 »
Anyone now how spacers go on the vertical tubing bender and the bronze bushing goes 704-273-6194
Legend199
Post by Legend199 »
I Lean wrote:Here is the vertical bender I built, designed to use JD2 Model 3 die sets. You'll notice on the drawing, the hole for the main die pin is undersized--I did that so I could drill it out to 1.25" to press bronze bushings into. All the other holes are just plasma cut.
I cut this from two layers of 3/8" steel just so the holes would be easier to get good quality, but if you wanted to just cut it from thicker material just don't cut the doubler pieces.
The second file I cut from 1/4" steel, and it's to hook the garage door extension spring underneath the ram, to retract everything when you release pressure.
Third file (Word doc) is just a parts list to complete the bender the same way I did mine. By no means is it the only way to do it, it's just my way. :D If you use different thickness materials, you may need to adjust the bolt and spacer lengths. How do the spacer go I can't figure it out u have pics or call me 704-273-6194
Vertical Bender - JD2 dies.dxf
Vertical Bender - springmount.dxf
do u no where the spacers go how wide is it at ate base is it 3 1/4 I.d. there is a 2. 3/8 in spacer a. 4. 1/2 spacers I u have pic of how it all goes
tylerd
Post by tylerd »
Badness!!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
Pecanman
Post by Pecanman »
I know this is a super old thread, but thanks for the files. I just finished mine today. I only have a hypertherm 30xp so I had to approach it a little differently.first I marked all the holes with the the plasma cutter and cut all the pieces out of 1/2". Then I lined up the corresponding pieces and tacked them together. I used my drill press to drill all the marked spots to size. I had everything ( even the right size bushings and the hydr cylinder) except the 5/8 bolts on hand so it was a very cheap build and I learned a lot and got a useful tool out of the process.
Wymanj
Post by Wymanj »
The jd2 die set I bought from jd2 has all 1” holes in it. I know the main center hole should be 1” but I guess I figured the others would be 7/8” like what we put in the arms. Is this correct or have they changed the dies? Can someone please confirm? The die set of have is 1.75” x 5.5”clr round bought directly from jd2.com. Thanks, Jordan
pvanweelden
Post by pvanweelden »
i wanted to say thanks to I Lean for uploading this- i am in the process of building one. i received a 1" 180 degree die from jd2 and the main hole and the guide piece hole are both 1.25". i am putting a bronze sleeve similar to the bushing used in the main hole on the bender plates. below is a couple of pics- i did a quick mock up to see how things were fitting (my base plates are attached to the outside instead of the inside, and my die was backwards, but everything is working as intended)
I Lean
Post by I Lean »
Wymanj wrote:The jd2 die set I bought from jd2 has all 1” holes in it. I know the main center hole should be 1” but I guess I figured the others would be 7/8” like what we put in the arms. Is this correct or have they changed the dies? Can someone please confirm? The die set of have is 1.75” x 5.5”clr round bought directly from jd2.com. Thanks, Jordan
I think that's probably right--I know the pins are pretty sloppy in the die holes. If mine aren't 1", they're still quite a bit larger than 7/8".
pvanweelden wrote:i wanted to say thanks to I Lean for uploading this- i am in the process of building one. i received a 1" 180 degree die from jd2 and the main hole and the guide piece hole are both 1.25". i am putting a bronze sleeve similar to the bushing used in the main hole on the bender plates. below is a couple of pics- i did a quick mock up to see how things were fitting (my base plates are attached to the outside instead of the inside, and my die was backwards, but everything is working as intended)
I bet you got a die set intended for a Model 32 instead of Model 3. Probably will still work just fine, with the bushing you used.
pvanweelden
Thanks ^ i lean, that is what i was guessing that i might have a 32 die. here is mine finished (still need to add the spring and paint it) and first tube bent. thanks again!
ETCWeld
Post by ETCWeld »
Nice Job!
RSMetalworks
Post by RSMetalworks »
thank you sir for the dxf files .This is sooo cool looking. I will be building this very soon for my business.
4eleven
Post by 4eleven »
pvanweelden,
I am interested in the little jeep in the picture. What can you tell us about it?
BMcCloy05
Post by BMcCloy05 »
Nice
Thank You,
Brandon M.
Star lab 5x10 (in the works)
Miller 211
