Vertical bender using JD2 dies
I Lean
Re: Vertical bender using JD2 dies
Post by I Lean »
A little update on my bender, still going strong. A couple years ago I changed it up a little, now it uses an electric hydraulic pump for more speed. I never use the air/hydro anymore.
Short video: https://www.youtube.com/watch?v=XW8l7jtBbGo
steel 35
Post by steel 35 »
Indeed more speed, that's nice.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
cguethert
Post by cguethert »
Does anyone have drawing using the model 32 dies? I'll be cutting from 3/4". appreciate it if anyone does.
pvanweelden
Post by pvanweelden »
4eleven wrote: Mon Feb 25, 2019 9:40 am pvanweelden,
I am interested in the little jeep in the picture. What can you tell us about it?
Sorry, havent been on here for a while- the "little Willys" is a 1/3 scale i built with a 79cc. does about 20 mph and can pull two adults (180 lbs each)
if you search youtube for pvanweelden, i have a few videos of it.
Thanks again I Lean- i used the bender and a modified HF/swag roller to make this ebike with an 11" wide rear tire
4eleven
Post by 4eleven »
The Jeep looks awesome! Nice job.
tehk
Post by tehk »
For those of you who used a hydraulic power pack and ditched the air, did you just connect the pack to where the old air cylinder was?
UrbanModern-Metalworks
Post by UrbanModern-Metalworks »
I have one of these Air/hydraulic cylinders and also have a Swag cylinder mount for sale. I just converted to Hydraulic. We are a production shop and I needed the speed for the volume of bending we do. Both the cylinder and swag mount are brand new. I have only bent one 1" .095 wall tube in it with the cylinder and mount. I have $265 into it. I would take $190 plus shipping.
Mstudt
Post by Mstudt »
I know it's a long shot considering the age of this thread.
Does any have a picture of one of these from the front? I'm have a difficult time figuring out where to put a 4-1/2" spacer when the widest part of my bender is is only 3-7/8". I've attached a picture from the drawings that show a 4-3/4" spacing. I would assume that distance would match the width of spacers so now I'm even more confused. I'm also not finding a spot to put a 2-7/8" since nothing measures that width. I feel like I'm missing some spacers somewhere, but everything I have matches perfectly to the materials list provided in the first post.
Mike
pvanweelden
The two arms that move with the ram mount inside of the main 2 verticals pieces of the bender. the 2 7/8" spacer is used at the moving arms. the 4 1/2" spacers go in between the main 2 vertical pieces.
Edit- corrected mistyped info
Mstudt
Post by Mstudt »
pvanweelden wrote: Tue Jan 28, 2020 3:41 pm The two arms that move with the ram mount inside of the main 2 verticals pieces of the bender. the 2 7/8" spacer is used at the moving arms. the 4 1/2" spacers go in between the main 2 vertical pieces.
I know where they go, but wanted to asked since the sizes don't match the drawing. The drawing measures at 4-3/4" between the verticals rather than 4-1/2".
I've changed it up some since there was quite a bit of play using the spec'd size spacers. I'm going to be using 4" spacers in the vertical spot, 2-1/2" spacers for the feet, and 2-3/8" spacers for the arms. This will allow me to run 1/16" oil-embedded bronze washers between the vertical pieces and arms, and the arms and die.
I'll try to post some picture when it's done.
Mike
blakeforslund
Post by blakeforslund »
This is one of the reasons i joined this group. Was looking to build vs buy tools, so i can build vs buy some automotive projects (roll cages, suspension, etc.) Looking forward to building this.
Swick73
Post by Swick73 »
Getting ready to build one of these. Can someone post some close up pics?
ETCWeld
Post by ETCWeld »
pvanweelden wrote: Thu Aug 01, 2019 1:21 pm
These are awesome! great work!!!
pvanweelden
ETCWeld wrote: Thu Feb 20, 2020 10:51 pm
Thank you ETCWeld! i am busy building another bike that i used this bender and a swag modified HF Roller for the tube work
DieselFumes
Post by DieselFumes »
Thats awesome! Love the bike, love your jig setup :Like :Like
Tracker CNC 4x4
ArcWrightFabWorks
Post by ArcWrightFabWorks »
Anyone cut this out of 3/4" I have some from another project and was wondering if someone had used it. Would there need to be any changes to the plans if I do that? Sorry a bit of a newbie.
Matt
Cutting Edge Plasma 4x4
Hypertherm Powermax 65
HTP Invertig 221
Hobart Handler 190
Inkscape / Qcad / Sheetcam / Fusion 360
Grizzly G4003g
Grizzly G0759
HatchMan
Post by HatchMan »
Long shot that someone will respond today, I am assembling my bender, and questioning where the two shorter spacers go? The long ones (4.5") appear to go between the long arms, and then there is a 2-7/8" and a 2-3/8" spacer, I'm guessing they go on the short arms, but why the 1/2" difference? where are they supposed to go? I don't have a JD2 Die yet, so I don't know how wide the opening inside the two short arms is supposed to be.
Any help/clarification would be fantastic.
Thanks in advance!
HatchMan
Post by HatchMan »
Nobody knows which spacer goes where?
HatchMan
Post by HatchMan »
Well I finally got mine built, works good, a bit slow, but better than manual for sure. Thank you for the drawings!!!Image
pvanweelden
That turned out great Kevin^ (Hatchamn) - saw your post on international Fab page.
I assume you figured the spacers out? honestly, they aren't that big of a deal- easy to figure out once you start putting it together- its vertical- it doesn't need to be tight, just enough room to get different width dies in there
- after 2 years I still don't even have the nuts on my two bolts where the 4.5" spacer are lol. two weeks ago I used the bender to make a drift trike
HatchMan
Post by HatchMan »
Thanks, I actually made a couple of spacers 2-9/16" and used them in between the small arms, the 2" JD die was 2-1/2" and so the die just slips in nice and any smaller dies are narrower, so I should be good to go.
Your trike looks awesome!! looks like a combo of bender and roller to build that?
pvanweelden
HatchMan wrote: Mon Apr 27, 2020 1:57 pm Thanks, I actually made a couple of spacers 2-9/16" and used them in between the small arms, the 2" JD die was 2-1/2" and so the die just slips in nice and any smaller dies are narrower, so I should be good to go.
thanks Kevin! yes, i have a swag offroad modified HF roller- you can see it in a video i did for the trike. my next video will have some of the vertical bender in action in it. https://youtu.be/Fu1eSjAgzas
HatchMan
Post by HatchMan »
pvanweelden wrote: Mon May 04, 2020 4:27 pm thanks Kevin! yes, i have a swag offroad modified HF roller- you can see it in a video i did for the trike. my next video will have some of the vertical bender in action in it. https://youtu.be/Fu1eSjAgzas
Very Cool Video!!! Looks like a lot of fun, I love the roller also, I may have to get one for some projects I can think of... Thanks for sharing!!
mcmental
Post by mcmental »
Great work, thanks for the file. I’ll download now
Hix
Post by Hix »
Hi,
Just joined this forum, as such I'm a little green on how to download files. It is a case of joining with the $20 sub option, or do you need more advanced membership for these files?
This is an awesome project and I'm really enthused by what I've seen on here so far.
I've got 20 years experience as a CADMonkey and am more than happy to help folks out, if I can.
Cheers
Ade
