20 Can spray bomb wall mount
Re: 20 Can spray bomb wall mount
Now I may get organized. Thanks for the two shares
very nice upgrade , just cut my first . Will definitely be doing the 2 break one .
Thanks to Allan101 and Old Iron for the file.
Walt
Walt
Now this is going to come in handy! Thanks Gents.
what a great idea. its the small things like this that some of us don't think about that really help.
- rons
Very nice but what we all need is a automatic can shaker
4x8 Home made with PPL Gantry
Bladder water table
Candcnc EtherCut + DTHCIV
Hypertherm PM 65 machine
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Ingersoll Rand 7.5 hp 80 gal
Harbor Ref. Dryer
Lathe, BP, 1" x 12" Cosan Miter Saw,
Bladder water table
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Harbor Ref. Dryer
Harbor Freight shaker works great!
Allen
Allen
fantastic idea sir, thanks for sharing...been looking for a good idea for bombs 6 months now..finally one that makes sense..thumbs up
looks awsome thanks
I cut the 20 can holder after I modified the file slightly. I wanted to hang it on the inside of my shop side door, and the leftover sheet of 14 Ga was only big enough for 34". So I scaled it in Inkscape all combined and this reduced the can opening down to 2-13/16" when cut with no offset. When I cut it the center line group cut from start to end and back to start without lifting the torch so I corrected ths in this attached file.
The expanded paint can holder wasn't quite 16" on center, so I moved the outside mounting holes in. This should be 16" on center now.
I wasn't quite sure what you meant, but now I see - you moved the holes for mounting to wall studs that are located 16" OC.
acourtjester wrote: Wed Oct 17, 2018 4:45 pm I cut the 20 can holder after I modified the file slightly. I wanted to hang it on the inside of my shop side door, and the leftover sheet of 14 Ga was only big enough for 34". So I scaled it in Inkscape all combined and this reduced the can opening down to 2-13/16" when cut with no offset. When I cut it the center line group cut from start to end and back to start without lifting the torch so I corrected ths in this attached file.![]()
20CanHolder.svg
Unfortunately for me, I would need very many of these to hold all my spray cans - and then of course wall space to mount them. But a great looking holder and I really like the color.
- Double S Farms
Very nice - thanks for the fine file!
Thank you. Exactly what I need.
Thanks for the file I mounted it vertically worked better for my use..
Nice! Looks awesome and great use of space.
Awesome - I'll be cutting these soon to help clear up some bench space.
