Some recent work
Re: Some recent work
David I did see the cold beer one posted (and here different shape) in a routed sign so the files may be posted somewhere, I really like the welcome one.
Nice work Beeson posts like this inspire others to have fun too.
A sign i made for a local motorcycle club, just waiting for it to be mounted.
Drop us a
on our facebook at https://www.facebook.com/jbengineering.boston
www.jbengineeringboston.com
Some creative work there, thanks for posting
Super cool design, looks greatbeeson1987 wrote: Fri Jun 09, 2023 12:33 pm A sign i made for a local motorcycle club, just waiting for it to be mounted.
Tracker CNC 4x4
Chris - very nicely done! What is the name of the club?
They're called 'The Divergent MCC' based in Lincolnshire, uk.
Drop us a
Chris - I thought that looked like a capital "A" incorporated into the piece, so I had assumed maybe their club name started with "A".beeson1987 wrote: Sat Jun 10, 2023 4:26 am They're called 'The Divergent MCC' based in Lincolnshire, uk.
But I guess I was wrong. Thanks!
m pretty sure its a capital A too. Unsure of the actual meaning behind the design etc. The guy i dealt with gave me a logo used on the clubs patch, and i just adapted it to make it work dxf format.
Drop us a
Another hanging sign. Created for a local tattoo shop.
Left bare metal finish, awaiting the customers paint scheme. Centre text has been made double sided so can be read from both sides. Hence the white panel.
Drop us a
Tattoo.
Drop us a
Nice work! I assume we are looking at the same side in both images. What does the other side look like?
- tnbndr
Nice work!
You could actually make the entire sign double sided. Cut two rounds and sandwich white or whatever color between them.
Weld one to the outer rim, insert color panel and then bolt the two together.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
Yes david, they are the same side. One has a ring around it for added strength as is going to be a sign that is hung outside the customers shop. The other is a sign that is fixed to the internal wall for decoration. The idea of just having the insert was that 'The Art Of Ink' was readable from both sides, the customer wanted the design to be as open as i could get it, hence why i didnt place to of them back to back.
Drop us a
A few from today.
Drop us a
Chris - I saw these but forgot to comment. More great work!! Keep them coming.
Something a little different today. A 6ft sleeping cowboy.
Drop us a
Checked out all your most recent work posted. It all looks fantastic but really like that cowboy, well done!
A bench ive recently finished.
Drop us a
Very nice! Modified an existing bench or built the bench from scratch?
Nice work Chris! I'm guessing this is a scratch build. My question is how did you bend the rectangular tubing? Or did you get pre-bent pieces and cut and weld them together?
All made from scratch. We have a set of rollers in the workshop i used to roll the box section. But couldnt get it enough, so had to cut every 1/2 inch and bend manually untill desired curve. Turned out pretty good imo.
Drop us a
When you sliced it every 1/2" to bend, did you weld in filler pieces and then grind smooth? Yes - it looks great!beeson1987 wrote: Fri Jul 28, 2023 2:41 am All made from scratch. We have a set of rollers in the workshop i used to roll the box section. But couldnt get it enough, so had to cut every 1/2 inch and bend manually untill desired curve. Turned out pretty good imo.
Yes, cut the thickness of grinding disc, then welded and smoothed.
Drop us a
Been a while since posted, so here we have todays bench, finished.
Commemorative D-day bench.
Lest We Forget, Includes images of Spitfires, Lancaster bomber, Winston Churchill , Big Ben, Houses of Parliament, Poppies, Tower of London, Tower bridge , St Pauls cathedral.
Drop us a
Amazing looking bench, great work! Do you build the entire bench yourself or customize a premade bench?
DIY 2x2 table
Everlast 82i
Everlast 82i
