Creating bolt patterns and flanges and scaling
Re: Creating bolt patterns and flanges and scaling
Fastyankee wrote: Wed Jul 10, 2024 2:14 am
I’m also interesting to know if there is a way to scale parts to different sizes. Such as say a fixture table were I have several .645 holes in a plate that’s 2x2 and I want to make the same plate in 4x8 but want to keep the same .645 holes. If I simply just use select all and enlarge the plate it will enlarge the wholes as well.If I use a scaling tool it will rescale the object with out effecting the hole size. Just not sure how to do scaling in Inkscape.
I assume you are talking about fixture plates/tables here with a grid of 0.645" diameter holes, say on a 2" x 2" spacing. If so, here is a method to do it using Inkscape. Once you have created your original file and saved it as SVG, you can reopen it and adjust the number of holes while keeping the hole spacing and hole size the same. You would need to draw a new rectangle to fit your new grid size.
https://photos.app.goo.gl/EtG6tH4xw3dkZqEA7
TJS
Post by TJS »
David,
Thanks. After you enter the rows and columns number do you just press enter. I know on some of inkscape executions you have to click Apply such as Transform. I do not see the apply button there but I do see a randomize.
TJS wrote: Tue Jul 16, 2024 9:36 am David,
As you enter the rows and columns numbers the drawing will automatically change/update to reflect your new entries.
TJS
Post by TJS »
Thanks David.
TJS wrote: Tue Jul 16, 2024 1:31 pmThanks David.
TJ - you are quite welcome! Do you have any upcoming projects where you will be creating a rectangular array of holes?
TJS
Post by TJS »
adbuch wrote: Wed Jul 17, 2024 3:09 am
Not yet. But as I said. This should be a sticky for the inkscape forum. Anyway I can search and find it.
Fastyankee
Post by Fastyankee »
Wow lots of good info on this topic.
Thank you all now to see if I can follow what your showing me.
AJ
irondeuces@gmail.com
Pulmax
5x10 Star Lab plasma, scribe, pipe cutter
60 ton 53” press brake
JD2 tube bender
Hulk Tube bender
Slip roll 3/16th capacity
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
TJS wrote: Wed Jul 17, 2024 10:19 am
I very much agree! I'm not sure how we would create a "sticky". Perhaps Admin could advise.
In any case, I bookmarked it for future reference. Lots of great information here.
Fastyankee wrote: Wed Jul 17, 2024 11:13 am Wow lots of good info on this topic.
Welcome back AJ! Let us know if you have any specific questions about any of this and we will try to help.
Pspider Support
Post by Pspider Support »
Hey TJS, we will make this topic a sticky for sure. One thing I will suggest for future reference of topics you don't want to forget about or lose track of, is to use the "Bookmark" feature. Super handy feature many don't know about. Once you "Bookmark" a topic you can go to your User Control Panel, click on Bookmarks, and view all Bookmarked topics. See image below showing where to go to Bookmark a topic your currently viewing.
Pspider Support
Contact Me via PM
Pspider Support wrote: Wed Jul 17, 2024 9:46 pm
:Like :Like :Like
Thanks for educating us on the "Bookmark" feature. I'll try it out.
TJS
Post by TJS »
Thanks. Bookmarked.
Hummm is bookmarking like extended memory. :HaHa :HaHa :HaHa
acourtjester wrote: Thu Jul 18, 2024 10:02 am Hummm is bookmarking like extended memory. :HaHa :HaHa :HaHa
Tom - I think it is.
Fastyankee
Thanks guys I'm still trying a few of the methods. You guys are way faster and more proficient than I am:)
AJ
Pulmax
JD2 tube bender
Hulk Tube bender
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
Fastyankee wrote: Fri Jul 19, 2024 1:20 pm Thanks guys I'm still trying a few of the methods. You guys are way faster and more proficient than I am:)
AJ - let us know if there is a particular file or design that is giving your problems and we will try to help you.
Pspider Support
:HaHa :HaHa I can confirm it is!!
Pspider Support
Contact Me via PM
Return to “Inkscape”
