Anyone located in Colorado Springs?
tcaudle
Re: Anyone located in Colorado Springs?
Post by tcaudle »
The ground are fine - checked by the electrician, the code inspector, and today by me.
Well, I certainly would not question that panel of experts.
tnbndr
Post by tnbndr »
Flatline16 wrote: Wed May 28, 2025 3:51 pm The ground are fine - checked by the electrician, the code inspector, and today by me.
Tom hasnt provided a tangible list to check at the start or in the current. Would be awesome to have an actual list!
Do you have these manuals?
New WinZip File.zip
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
DieselFumes
Post by DieselFumes »
Flatline16 wrote: Wed May 28, 2025 3:51 pm The table has been moved, set back up, and the stepper ran out of data error happens, the DTHC according to MACH is always on no matter if I turn it off, the torch only fires once until I unplug the hub, when cutting the torch fires for about 1 inch then looks like it lifts, shuts off and continues motion of the cut. Ill upload a video later.
With your torch lifting during the XY move and them shutting off, your DTHC is def on and I realize you are having trouble shutting it off. I would completely eliminate the DTHC equipment and just use XY motion for testing and see if the DTHC has something to do with the data feed being stopped.
Tracker CNC 4x4
DieselFumes wrote: Thu May 29, 2025 12:20 pm
:Like :Like
Return to “CandCNC Forum”
