EASYSCRIBER QUESTIONS
All topics related specifically to the EasyScriber drag style scribe & engraving tool.
EasyScriber
Re: EASYSCRIBER QUESTIONS
Post by EasyScriber »
Dragfluid wrote: Sun Oct 20, 2019 3:48 pm BTW, this will be used on a PlasmaCam DHC2, with the 3.11 software. Anything in particular to be aware of?
Nothing else, your good to go.
Just visit this link to see the settings for EasyScribing with PlasmaCam viewtopic.php?f=172&t=28846
Let us know if you have any additional questions :Like
JohnnyC
Post by JohnnyC »
I need settings for wincnc can anyone help?
EasyScriber
JohnnyC wrote: Tue Feb 25, 2020 5:56 pm I need settings for wincnc can anyone help?
Have not had the opportunity to run one using WinCNC. What problems are you seeing?
JohnnyC
Post by JohnnyC »
I talked to my table rep and he got it working. You may want to get a copy of WinCNC so you can give instructions
EasyScriber
JohnnyC wrote: Fri Feb 28, 2020 2:19 pm I talked to my table rep and he got it working. You may want to get a copy of WinCNC so you can give instructions
That was our first move since there is a demo of WinCNC available however without the hardware on the other end to actually test we could not confirm anything. Very interested in what you learned and how its working for you.
JohnnyC
Post by JohnnyC »
Have to go into WinCNC every time and change all instances of 2 lines of code. It works alright so far
BLUFLAME-FABRICATION
Post by BLUFLAME-FABRICATION »
Weldguy How did you cut it out after engraving? Cut first then engrave?
weldguy
Post by weldguy »
Because this needed to have the markings in the paint this piece had to be cut and finished before scribing.
Return to “EasyScriber Drag Style Scriber for Hypertherm”
