Comments for or against QCAD/CAM?
Re: Comments for or against QCAD/CAM?
CWPlasma wrote: Sat Sep 21, 2024 8:38 pm I use Qcad almost every day, it works great for what I need to do with it, which is mostly parts, and less art. It does work great for modifying art drawings too though. It was very easy to learn compared to others I've tried.
CWPlasma- that's great to hear! I like it also - it reminds me very much of the older versions of AutoCad - nice and simple to use. My only gripe is with the QCad trim tool - for me it sometimes gives unexpected results - so not as intuitive as the trim tool in some of the other programs I use.
What kind of projects are you working on with QCad? Perhaps share a few photos.
CWPlasma
Post by CWPlasma »
Here is a few examples.
CWPlasma
Post by CWPlasma »
The artistic stuff I download images, is inkscape to vectorize them, and then modify in qcad to make them what I want.
CWPlasma wrote: Mon Sep 23, 2024 7:27 pm The artistic stuff I download images, is inkscape to vectorize them, and then modify in qcad to make them what I want.
Very nice!! You do some pretty heavy duty stuff, in addition to the smaller plasma art projects. I was following that fire pit thread where you had calculated the bend angle for the sides. Would you mind sharing how you did it - perhaps with a drawing? I tried to calculate it myself, but was not coming up with the correct angle.
CWPlasma
Post by CWPlasma »
I will, but it will probably be a couple days before I can sit down and do that.
CWPlasma wrote: Mon Sep 23, 2024 8:05 pm I will, but it will probably be a couple days before I can sit down and do that.
:Like :Like :Like
CWPlasma
Post by CWPlasma »
The heavier stuff is for the shop I work at, and the smaller and artistic are things I make on my own time. Qcad is about perfect for shop work for us, and I find it easier to edit clipart drawings and such in Qcad than inkscape anymore, for me.
CWPlasma wrote: Mon Sep 23, 2024 9:15 pm The heavier stuff is for the shop I work at, and the smaller and artistic are things I make on my own time. Qcad is about perfect for shop work for us, and I find it easier to edit clipart drawings and such in Qcad than inkscape anymore, for me.
CWPlasma - that's interesting that you are editing the clipart with QCad now instead of Inkscape. QCad does let you drag individual nodes around - so I can see how that may be useful for "fine tuning" art type drawings.
By the way - I did take another look at the bend angle calculation for that hex fire pit - and this is what I came up with. I will be interested to see how your method compares. My result was pretty close to your 52 degrees.
AJ - did you ever order your Design Edge software? If so, how do you like it so far?
Fastyankee
Post by Fastyankee »
adbuch wrote: Mon Sep 16, 2024 2:35 pm AJ - a while ago you posted a question in the Inkscape section about a file with many disconnected path segments - Eagle Tattered Flag dxf shared file.
viewtopic.php?p=237069#p237069
At the time we suggested using LightBurn to link/join this file. I also seem to remember that you had another file later on where LightBurn would not completely link/join the file.
Design Edge will link/join problematic files like these with a single command. Select all, type "J" to link/join, and file is fixed.
Dave I broke down and purchased Design edge Advanced when it was all said and done it coast me $5,000 which seems much but worth it to me. I now have to learn it now ugh. I don't see were I can open SVG files. I purchased the Advanced version so I could import export SVG and EPS files. I downloaded the software from the owners page because I cant load a CD on my laptop. So I'm not 100% I got the full version because it wont open let me open SVGs and it seems I don't have all the functionality.
AJ
irondeuces@gmail.com
Pulmax
5x10 Star Lab plasma, scribe, pipe cutter
60 ton 53” press brake
JD2 tube bender
Hulk Tube bender
Slip roll 3/16th capacity
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
Fastyankee
AJ
Pulmax
JD2 tube bender
Hulk Tube bender
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
My biggest complaint about QCad is that it lacks a proper "Trim Tool". I know others who do use QCad and they agree, but are used to the QCad methods and go ahead and use it anyway. I have used QCad and purchased a license, but have not used QcadCam.
