Can any of you tell me why am I getting these foggy areas from my clear coat? I am using rattle can clear coat for metal.
Clear coat fog or bubbles?
- Baileigh Inc
Shane Henderson
Baileigh Industrial
shenderson@baileighindustrial.com
920-482-3220
Serious metal fabrication equipment
Baileigh Industrial
920-482-3220
- AnotherDano
Re: Clear coat fog or bubbles?
Are you using hot or cold rolled steel?
Looks like P&O or hot rolled to me.
The mill scale might be the problem.
It's like putting a liquid on wood which changes the color.
Dano Roberts
droberts@ironpequod.com
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
- Baileigh Inc
It is hot rolled that has been primered and spray painted black.
Shane Henderson
Baileigh Industrial
920-482-3220
Baileigh Industrial
920-482-3220
My guess would be too much moisture in the air.
- Baileigh Inc
Crap! I was afraid of that.Mr.Dirt wrote:My guess would be too much moisture in the air.
Shane Henderson
Baileigh Industrial
920-482-3220
Baileigh Industrial
920-482-3220
Yup...humidity will do it.
Allen
Allen
- tnbndr
Yes, humidity will do that but also overspray will cause similar results.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
- Baileigh Inc
tnbndr wrote:Yes, humidity will do that but also overspray will cause similar results.
I think it was a little of both. Thanks!
Shane Henderson
Baileigh Industrial
920-482-3220
Baileigh Industrial
920-482-3220
I've experienced the same results with spray can clear coat.
I was using Rust-Oleum Triple Thick Glaze Clear.
I was spraying it on from to far of a distance from the piece. Instruction's recommend 8"-10".
I was 12" to 16" off piece.
RH
RH
