Help resizing for 16ga. 3D Deer Head
I got this file off here and was wondering if someone could resize the slots to fit 16ga. steel. Thanks in advance!
Re: Help resizing for 16ga. 3D Deer Head
Just change the widths to about .1" wide instead of .2" wide. It shouldn't take you that long to do. .1" might be to small depending on the bevel of your cut.
Ted
Pcam DHC2 with the works
PM 30, 45 & 65
Corel Draw X6 - Adobe CS5
Ted
PM 30, 45 & 65
Just curious, do you want to resize it because that is the size material that you want to use, or because you want the completed product to be small? I made one out of 12ga and it was really small. 16ga would be tiny. If you reduce the whole nest of parts so the the slots match 16ga, it will be tiny. If you reduce just the slot size, you can make it as big as you want just out of 16ga material.
Im trying to make the head out of 16ga. but I want it to be the same size as in the picture. I cut this out and it turned out pretty good but was a pain to weld because of the slop in the slots! Just wanted the slots smaller so it fit 16ga. material. Im just to "new" at drawing in Corel to figure out how to make it work
OK , so how wide do you want the slots to be ??
16ga is about .060" thick
How wide is YOUR average kurf width (width of cut) for cutting 16ga ?
(;-) TP
(;-) TP
I'm not sure what my kerf is but I'm using a hypertherm 65. I think somewhere around .065 would be good! Thanks
Kerf width should be immaterial as it's adjusted on conversion to cut path/ G code
Murray
Murray
Actually kerf width CAN be important in your cutting solution. IF you are wanting a slot width of say .060-.065" then the cut would be a single line cut. Trying to make a SLOT cut may lead to a bad cut as you would be cutting a lot of air on the second half of the cut making it a lot wider than you wanted it to be.
(;-) TP
(;-) TP
