45 ISSUE
tdalechick
45 ISSUE
Post by tdalechick »
On the hypertherm 45 the torch was working great and then it stopped and all the lights on the machine are flashing on the front panel....What could be the cause of this? I had just changed out the consumables and its not super tight or loose.... Air pressure is good but when you turn the knob to air nothing is coming out.....I reset it and its still not working. Anyone else ever have this problem and know how to fix it??? Please let me know. Thanks!!!
greenranger620
Re: 45 ISSUE
Post by greenranger620 »
Check the swirl ring if it is upside down torch will not fire properly and may not fire with those consumables try a new set and holes in swirl ring towards torch tip,power down then power back up should be good to go
