Rounded Corners
grindergary
Rounded Corners
Post by grindergary »
I am having trouble with corners being rounded off when cutting. I am cutting rectangles 6" x 12" 16 ga plate with 45 amp fine cut. Running book values.
I have cut alot of parts for signs and misc parts but have nor had this occur before.
Most parts come out almost dross free and look very nice.
The start point is at one corner and will end up square. The other 3 will get rounded. I have not changed anything on the machine at all. Checked for slack in the machine and everything seems right.
Mach is set to motion mode - constant velocity
distance mode - absolute
IJ Mode - Inc.
When I am cutting thicker material, there is no issue with corners.
Any ideas would be appreciated!
Gary
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
abmagrum
Re: Rounded Corners
Post by abmagrum »
Gary
see if this helps
go to http://arclightcnc.com/training.html
click on video 9 sheet cam whati think you want starts at about 11 minutes
hope this helps
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
grindergary
Re: Rounded Corners
I checked it out but my problem is more with acceleration and velocity. I turned them down because my gantry was racking. I fixed that and reset the settings and made a big difference.
Gary
Sheetcam, Mach 3
SeanP
Re: Rounded Corners
Post by SeanP »
Gary I tried these settings in mach/general, it helped no end on my machine.
It was just inside offset cuts I had problems on corners though, outside offset was fine.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
grindergary
Re: Rounded Corners
Thanks for the reply. Mine seems to be outside corners.
Resetting helped alot
Gary
Sheetcam, Mach 3
grindergary
Re: Rounded Corners
SeanP wrote:Gary I tried these settings in mach/general, it helped no end on my machine.
SeanP,
I tied your settings and they work great for those inside corners.
My problem now is to clean up the drawings as it seems the torch stops at every node in a complex cut.
Gary
Sheetcam, Mach 3
abmagrum
Re: Rounded Corners
Post by abmagrum »
hey,Gary
do you have corel draw ? if so there is a plug in called dxf pro tool it eliminates the extra nodes automatically'.
you can try it for free for 30 days no catches.
http://www.coreldrawtools.com/professional/
its works great.
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
grindergary
Re: Rounded Corners
Thanks abmagrum,
I will give it a try. I use the dxf now but still seems like alot of nodes.
Gary
Sheetcam, Mach 3
