I recently purchased the Magnetic Breakaway retro kit for my AVHC and after installing it I noticed the AVHC was no longer adjusting the height during the cut and it would raise the torch 1/16 during a long cut and hold it there until the cut completed, it was showing the voltage on the controller but the led that flashes during adjustment was not flickering as it was previously. I called support and they had me re download to the motor and still nothing so Tech support was going to contact the AVHC engineer Monday morning and get back to me. We did notice during testing that it worked fine in manual mode. So today I decided it had to be the magnet in the new breakaway causing the issue so I uninstalled it and re installed the old lifter block and it's working just fine as it had before. To be sure this was it I put the magnetic breakaway on and started a long cut and it was in auto mode and was not adjusting, I paused the cut unscrewed the two pinch bolts on the bottom of the lifter station and ran the drive screw down and removed it out of the bottom and put the old non-mag lifter block back on and resumed the cut and it was adjusting as it should with the led flickering.
I was hoping some of you would confirm that your mag breakaways are working correctly with the Animatics SM2315D servo on the lifter station.
Weekly Free DXF Design
AVHC Magnetic Breakaway Interference.
1 post
• Page 1 of 1
- modelaratrod
Post by modelaratrod »
5x10 Torchmate 2 w/AVHC
Hypertherm PM85 w/ machine & hand torch.
1 post
• Page 1 of 1
Jump to
- Welcome Center & Meet Our Sponsors
- ↳ Introduce Yourself
- DXF Design & Project Picture Sharing Forums
- ↳ DXF & SVG Categorized Library
- General Forums
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- Plasma Cutter Forums
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- CNC Plasma Table & Controller Forums
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FastCut CNC Website
- ↳ FlashCut CNC Forum
- ↳ FlashCut CNC Website
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Shop Sabre Website
- ↳ Star-Lab CNC Forum
- ↳ Star-Lab CNC Website
- ↳ Tracker CNC Forum
- ↳ Tracker CNC Website
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- CAD-CAM & Control Software Forums
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ CorelDRAW Free 15 day trial
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- Metal Finishing Forums
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- Accessories & Tool Related Forums
- ↳ Laser Engravers & Cutters
- ↳ Arclight Dynamics
