Homemade Tubing roller drives...any ideas?
- 1fine79
Been wanting to build myself a tubing roller for those long arch projects like gate tops or arched entrance signs. I have JD2 bender that works awesome, but rolling is what I need. I build a lot of my own tooling so I have a pretty good idea how I want to build it, but what I really need is some possible ideas on how to power and drive this thing. Anyone got an idea how to do this (low budget)without having to spend a fortune on geared DC motor drives or such. I worked with a guy years ago that made one from a 12V anchor winch from a sailboat and it worked pretty good...something like that is what I had in mind but I live in NW Georgia now and there aren't that many sailboats to get old parts from, if you know what I mean. I know you DIY guys like me have some great ideas, can't wait to hear from you.
Wayne
Torchmate 2 self-built 5x10 w/ SS water table AVHC New
Hypertherm PM65 New
Miller Spectrum 2050 hand torch
Miller Syncrowave 250 DX
Millermatic 212 w/ spoolgun
Lincoln SP-250
JD squared Model 32 hyd.bender
Hypertherm PM65 New
Lincoln SP-250
Re: Homemade Tubing roller drives...any ideas?
I cant seem to find the video, thought I saved it, but there is a youtube video out there where the builder used a Harbour Frieght electric drive pipe threader. Low speed high torque, and worked great. You simply need to weld a nut of the appropriate size on the roller that you want to be your drive roller. has a forward and revers already.
best of luck, I'm thinking of building one soon as well.
edit...
http://youtu.be/OM_QyvTCsyk
edit...
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
that would be old sarges video
he does awesome work
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
Heck, I'm in the market for a lathe just so I can turn my own dies for whatever I want to roll!
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
- tnbndr
Try these posts:
viewtopic.php?f=12&t=11843&p=65568#p65568
http://www.pirate4x4.com/forum/shop-too ... eview.html
http://www.offroadfabnet.com/forums/sho ... php?t=9696
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
- 1fine79
Dennis,
Thanks for the links....I think I'm going to follow the lead of one of the guys that is building his with exterior dies. this will allow for easy ring rolling (without disassembly of the whole top half of the machine) and very quick die changes.
Also, I got some ideas from one video about making some adjustable die sets for square, angle and channel so you don't have to have one for every shape you roll (though the rounds have to match, so you cant really make those adjustable). Of course, this will limit the overall strength and capacity of the roller but i'm not looking to roll any 6" channel or 4" angle anyways. One thing that makes sense to me is to power all three rollers so you get a real smooth movement with out the slippage of a one powered roller setup, but IDK maybe slippage is not really an issue.
Anyways....still thinking and designing this thing in my head. As soon as I get started, I will post my progress and maybe with everyone's input, we can build one heck of a tubing/angle/channel/flat bar/etc, etc, etc roller.
Oh,yeah! I can already see those sleepless nights coming! Anyone have any suggestions on some good brain food? Mine is feeling a bit malnourished lately....LOL!
Wayne
Hypertherm PM65 New
Lincoln SP-250
Hypertherm PM65 New
Lincoln SP-250
- tnbndr
Look up Eagle bending machines and download a user manual. That is whAt you want to build. They have variable dies.
Harbor freight sells a cheap tube roller that works pretty well.
