Well I finally got this project done. A local contractor brought by a rough sketch (like in pencil scratched out on the back of an old envelope) of a sign he wanted for a new coffee shop he was working on. He gave the particulars that his customer had asked for, like they wanted it back lighted and they wanted it to be very old and rusty looking (like an old barn find sign) so we came up with this little beauty. As it just so happened...I had just received my very first shipment of goodies from SteelFX and was chomping at the bit to find something to use them on....wow, perfect timing! After some phone conversation with Bill about the best way to achieve that perfect patina....it turned out pretty nice. Thanks Bill!!!
Oh...and BTW...when you order your LED light kits online, make sure your not ordering them out of Hong Kong. Yep that's what I did....good deal but it took nearly 4 weeks to get them here.
Our latest lighted sign
- 1fine79
- Attachments
- Wired coffee bar sign patina web.jpg (103.76 KiB) Viewed 2065 times
- Wired lighted sign web.jpg (102.24 KiB) Viewed 2065 times
Wayne
Torchmate 2 self-built 5x10 w/ SS water table AVHC New
Hypertherm PM65 New
Miller Spectrum 2050 hand torch
Miller Syncrowave 250 DX
Millermatic 212 w/ spoolgun
Lincoln SP-250
JD squared Model 32 hyd.bender
Hypertherm PM65 New
Lincoln SP-250
Re: Our latest lighted sign
Well I say you should get a nice pat on the back
"job well done"
"job well done"
AWESOME. Would you mind sharing what the treatment was to get that finish? It is clearly more than just spray RustFX. Looks like there may have been some fabric or something left on it to develop the grain look in the rust.
Byron
Byron
Precision Plasma 4x8 v-rail
C&CNC dragon cut 620
Hypertherm Powermax 45
Auburn, AL
www.facebook.com/decorativemetalworks
Auburn, AL
- 1fine79
Nope, no fabric used, here's what I did. I laid the sign flat and evenly sprayed it with RustFX. While that was doing it's thing, I came back and sprayed some AuburnFX in different spots to get that darker blotched color effect. I left that to develop rust and color for an hour or so in the sun. It all looked ok but I thought it needed more "age" so I took the RustFX again and opened the tip up to a very splattering spray and just let some big drops fall on the sign. As that was "cooking", I picked up the top end of the sign and let some of the solution run down the face where it wanted to. When it developed more and it looked good to me, I rinsed and dried it and clear coated it with Satin clear ( wasn't looking for a glossy finish) and TAH DAH, it was just what the customer wanted.
I can't wait to get into some more of my SteelFX goodies and experiment with some of the other finishes.
Wayne
Hypertherm PM65 New
Lincoln SP-250
Hypertherm PM65 New
Lincoln SP-250
- tnbndr
How was the lighting applied? What did you use for lighting?
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
- Sampson Jones
What font is "wired "?
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
CandCNC electronics
Command Lineux
Super z 2
- 1fine79
The lights are an LED strip. comes with a self-stick tape backing. Came in a light kit with 12v power supply from LED light world online (caution...if you are looking for quick delivery, go somewhere else. these took nearly 4 weeks to get here from Hong Kong)
The font I used for 'Wired' is called caslame and I found it on one of the free font sites...can't remember which one but you can do a search and I'm sure it will pop up somewhere.
Hope that helps.
Hope that helps.
Wayne
Hypertherm PM65 New
Lincoln SP-250
Hypertherm PM65 New
Lincoln SP-250
- Larry83301
Sampson Jones wrote:What font is "wired "?
Great sign, thanks for showing it!
Here's the font for any that want it - - - http://www.dafont.com/search.php?q=caslame&text=WIRED
Looks like a great one to add to the tool box!
- Craig
Nice sign good use of LED's. I also use local suppliers for LED's that way if you have problems you are more likely to get a resolution. Craig Johnson
Craig Johnson
