What is causing this?
M & N Steel CNC
Post by M & N Steel CNC »
Everything was cutting good then, sparks started flying and cut looks like this?
Can someone tell me what my problem is???
12 gauge, 100 IPM, Thermal dynamics A40, THC on, 108 volts.
Started file again and same result just never cut good, did a test cut and same result.
PlasmaRoute CNC 4 x 4
Corel Draw X5
SheetCam
Baileigh 12 gauge 40 inch box brake
davek0974
Re: What is causing this?
Post by davek0974 »
Is that the back or front?
I have had similar on my little machine which was caused by a lump of dross stuck on the front of the nozzle, no damage was done to the nozzle, just scraped it off and it was fine again.
M & N Steel CNC
That is the top, I checked the nozzle and electrode, cleaned them off and
now that is the way it wants to cut:(
Corel Draw X5
SheetCam
davek0974
Post by davek0974 »
Is the nozzle orifice still perfectly round and not blown out one side?
M & N Steel CNC
Yes, it appears to be in good shape, guess I will change it to see what happens.
Corel Draw X5
SheetCam
rikduk
Post by rikduk »
First, change your consumables to rule that out.
Then, it might look like you're too high/too fast.
Or lack of air pressure.
If you've been running for a while,I would check #1, then
#3, then #2.
