Mach3 jog rate
Mach3 jog rate
I am running mach 3 on a home built table. Everything has always worked fine. Now my arrow keys only jog at about 1.6 when the rate is set at 100. Not sure if I accidently changed a setting.
- tnbndr
Re: Mach3 jog rate
Mine has a continous jog rate and a step jog rate and the speed of the jog is a percentage. I believe it is based on a percentage of the 100% jog rate that is entered in the Mach 3 profile.
My guess is your percentage number changed somehow, or the jog rate in your profile.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
- chasxjs
Re: Mach3 jog rate
Are you holding down the shift key when you press the arrow keys or just pressing the arrow keys?
If the jog speed returns to normal when holding down the shift key while you use the arrow keys, check your slow jog rate by hitting the tab key. It may be set at a very low percentage.
Charles
____________________
DIY 5x5 Folding Plasma Table
Hypertherm PM45
Lagun 4 axis CNC Mill
Shopsmith Lathe
Multiple saws, welders, etc.
Hypertherm PM45
Shopsmith Lathe
Re: Mach3 jog rate
Thanks but I figured it out. I went into "restore" and went back a few sessions. Everything is working fine
