\cutting shapes
gasserman
\cutting shapes
Post by gasserman »
hello trying to cut acircle with circle in middle have put each circle on its own layer but both circles look egg shaped and off center ,using sheet cam ,please help
tnbndr
Re: \cutting shapes
Post by tnbndr »
On what table, plasma with what software?
Try a search in the different forums.
See this:
http://www.plasmaspider.com/viewtopic.php?f=4&t=16123
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
gasserman
Re: \cutting shapes
Post by gasserman »
we havbe retro fitted a farley wizard table with stepper motors torch height control floating z ,running mach 3 and sheet cam
gasserman
Re: \cutting shapes
Post by gasserman »
also when cutting a round disc circle start and finish is different
chasxjs
Re: \cutting shapes
Post by chasxjs »
If your start and finish positions are different, you either are loosing steps, or you have excessive play in the axis drives. What type of drive system are you using? Chain, rack and pinion, leadscrews?
Energize the stepper motors and then try to manually move them back and forth while looking for any play. Double check the gears on the motors.
Also it may help to post pictures.
Charles
____________________
DIY 5x5 Folding Plasma Table
Hypertherm PM45
Lagun 4 axis CNC Mill
Shopsmith Lathe
Multiple saws, welders, etc.
