Best way to convert template to cut file??
jlogan73
Post by jlogan73 »
I'm looking for the best way to take a "cutout" template and turn to cut file. I tried taking picture, put into Inkscape turned out Ehhh,,,
Just trying to learn what other ways there are.
It's a spot light mount for my jeep.
3.75" wide by 6" high.
Thanks for any help
ben de lappe
Re: Best way to convert template to cut file??
Post by ben de lappe »
I don't know if you may have something similar or not but this is one instance where Torchmate CAD shines with it's scan and trace wizard. I can take a piece such as this, place it on the bed of my scanner and bring it directly in to CAD. The better the template the better the part. This has saved my hide on more than one occasion.
Capstone
Post by Capstone »
Something this basic is better designed from scratch just based on measurements.
If you have a bunch of curves, then scanning smaller parts or taking a top down photo with a hi-res smart phone is a better method.
Lastly, you could add the Scanythinghardware/software and "trace" the part using your table. with less than $50 in expense.
I use all three methods.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
HI jlogan73
Here is a way to do it in Inkscape I did a screen shot of your part (jpeg) loaded it into Inkscape. Traced it to get paths of the part which also included the outside box around the drawing. Clicked on the path menu and clicked on break apart this separated the 2 paths then deleted the outside box path. Then go up to the top and click on the width and height boxes and entered your dimensions 3.75 X 6 inches and come up with a SVG file. A better image or flat bed scanner image would have been better to work with.
template.svg
(2.9 KiB) Downloaded 90 times
template.svg
jlogan73
Post by jlogan73 »
Thanks for all of your help!
james.davis
Post by james.davis »
I enlarge your bracket to 3.75x6.I use coral draw x7 I still have a lot of clean up on most things I convert from pics.
Jim
bracket.dxf
(4.91 KiB) Downloaded 101 times
bracket.dxf
Gamelord
4.5 Star Member
4.5 Star Member
Post by Gamelord »
Easiest way I have done it is to just place it on a scanner with the lid off and scan it directly into Corel. With the lid of the scanner off, everything on the outside will be black while the part will show up white. Once done, trace it and it should be nearly identical. If you need to do some minor tweaks then you can do that with the sizing tool in Corel.
I do echo the above though, with a part that is that basic, drawing it from scratch should take less time than the scanner thing.
Torchmate CAD
_Ogre
Post by _Ogre »
when i scan or take a picture of a template or object i usually include a ruler in there to scale the pic in autocad
Bobcat320
Post by Bobcat320 »
Capstone wrote:Something this basic is better designed from scratch just based on measurements.
Hey Capstone,
Do you know if Scanything will work with PlasmaCams Design Edge?
Carl
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
beefy
Post by beefy »
Carl,
I'm pretty sure it only works with Mach3 and the software from Edingcnc.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
