DXF convert to SVG
Inkscape related questions and tips can be posted to this topic.
Bigdogbro1
DXF convert to SVG
Post by Bigdogbro1 » Fri Oct 23, 2015 8:07 am
Hello,
I am saving the Solidworks 2013 .sldprt 3D files as 2D DXF and then import into Inkscape. Seems that the DXF files when brought into Inkscape thru import don't have the vector nodes connected together as a continuous line. I tried Inkscape COMBINE and more. Nothing seems to get the nodes connected. I've looked a software but it's pricey.
Any help would be great.
Re: DXF convert to SVG
Post by acourtjester » Fri Oct 23, 2015 8:55 am
for Inkscape to bring in a DXF of SVG use the open command above the import command under the file tab.
I don't know about 3D files formats but this works for 2D fine.
Everlast PM 256 tig
Bigdogbro1
Post by Bigdogbro1 » Thu Nov 05, 2015 8:04 am
Thanks, but the DXF files are 2D and when brought into Inkscape none of the lines are connected. They are all just segments.
Return to “Inkscape”
Industry Pros use FastCut CNC
