Im trying to hook up a mp3000 to a PCNC table. I have two questions does anybody out there know how to hook up the MTA150 card to the PCNC servo driver. There are no wiring diagrams of the servo driver to let me know where to hook up xyz dir and step. Second I know that I need the homing switches but do I also need to install three more limit switches. Any help from anybody that has done this conversion would be much a appreciated.
thanks
kevin
NEED HELP
- Loyd
Re: NEED HELP
Try this website, he is also a member of this forum.
http://priority1signs.com/index.php?id= ... C-retrofit
Loyd
Loyd
- jeeplogic83
Re: NEED HELP
Kevin did you figure it out? Sorry I did not reply earlier but I was out of town with no internet. If my site does not help my # is on the site give me a call and I will try and help you out.
Re: NEED HELP
Thanks Greg
I did figure out the MTA 150 card. Come to find out that it is not needed with the PCNC servo driver. I do think that i am going to just install the homing switches at this time untill things are working correctly. I am how ever a little woried about Mach 3 and Sheet cam sounds like it could be a long learning curve.
Kevin
Kevin
- jeeplogic83
Re: NEED HELP
You have to install the homing switches in order to calibrate your machine. I don't know if you have servos or steppers but the X and Y on my machine are 1911 steps/inch and the Z is 10,000/inch. This may be different for you but the machine ratios should be the same. 5:1 on the Z and 2.625:1 on the X and Y.
Good luck
Also get on the yahoo group CandCNC tom is very quick to answer questions.
Good luck
- Loyd
Re: NEED HELP
Loyd likes the "1911" steps per inch......good ole .45 caliber.....
Loyd
![Wink ;)](./images/smilies/icon_e_wink.gif)
![Cool 8-)](./images/smilies/icon_cool.gif)
Loyd
