limit switch activated
anyone know why i keep getting a limit switch activated signal when the torch shuts off with m05 or the torch passes the edge of the metal. it activates a limit switch after the m05 shutoff maybe twice on a 20 letter sign cutout even with thc off.
Re: limit switch activated
Have you looked at the Diagnostic page to which switch is tripped or is it just making the reset come on with not indications of which switch.
If you can see if its one switch all the time it could be a noisy switch just change short around it.
If its no switch then you have noise on the system causing the reset to tip.
Send more info
Send more info
they are all connected together because of the thc, in diagnostics it shows all linits and homes activated. could i switch them off one at a time maybe?, its hypertherm 45,with floating head ,tb6560 controller,mach3 and sheetcam.thanx dave
Ok what you need to make is a small jumper to short each switch one at a time to find the one causing the problems.
Just to clarify do you have the 3 axis limits tied to one pin and the floating head on another one separately. I have all my limits, home, and floating head switches on one pin and the ohmic sensor on a separate pin.
After reading your first post do you have THC electronics on your table if so you may be seeing this as a result of loosing ARC OK.
I don't remember what error I get when the torch goes outside the metal.
Go into mach, and Confiq/General Confiq/ find the debounce setting and move it up 25.. Keep going until the problem goes away.
no ohmic sensor,thc is proma and is unpluged from 12v when running machine,floating head switch on own self pin,limit switches on one pin and ground,other 3 pins are on proma up-down- arc ok. 5 pins in all 4 grounding pins .dave
ok in mach debounce is set to 0 and index debounce is 0 witch line do i set. thanx dave
Top one.. debounce interval is the one to bump the # up.. Leave the index debounce set to zero.. I asked Tom years ago about that one, and it's not something we need to worry about. So I never have..
hey great problem solved,worked on 4 cutouts not one problem. thanks dave
