Cannot access motor tuning
Searchman
Post by Searchman »
I cannot access " Motor Tuning " in mach3. The research I have done online indicates that the file for motor tuning may have been renamed. The guy " Lightning Mfg " I bought the table and computer from possibly did that to prevent tampering with the settings. He is no longer accessible. If I knew what file I was looking for in Mach I could rename it. Any suggestions ? Thanks
Re: Cannot access motor tuning
I assume you are talking about doing the steps per cals for each axis.
I had posted this earlier in Mach go to View and then load screens. The will bring up the Mach folder and you will see some screen files that have the file extension .set, click on plasma.set. The screen will go blank for a few seconds and them you will see the normal Mach screen which will have the settings tab. you can go from there to do the steps per calculations. After your done go back to load screens and select your screen to get back to where you were at the start.
Return to “Mach3 & Mach4 CNC”
