torch height on or off whats better?
Dustan
Post by Dustan »
Just wondering what everyones thoughts are on cutting with the torch height off or on .I was told that on fine artsy stuff OFF is the way to go and on parts and simple stuff ON is they way to go looking for any feedback on that as my source isnt as experienced as some of you may be . I do realize that if the metal to be cut is bend or curved ON is the answer Im talkin perfect flat conditions. :idea:
Krazy Kutz metal designs
plain ol Bill
Re: torch height on or off whats better?
Post by plain ol Bill »
On. I leave mine on all the time unless I am cutting small diameter holes.
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
Dustan
Post by Dustan »
If i am cutting parts or intricate drawings it seems to dive the torch at the end of the cuts causing it to stop suddenly and I then press run and it usaully goes to the next cut but sometimes brings up a code in mach3 that says something like r jk words all missing from line 2497 or whatever its on when it happened and wont let me keep cutting any ideas what that might be as i would prefer to use the DTHC although thats why its there right.
Deffinetly on. Do you have the option for fast and slow up or down? If you have problems diving at the end switch to slow.
Dustan
Post by Dustan »
I will definately look into it thanks
Bigrhamr
Post by Bigrhamr »
I don't know your machine or software but with some there are settings to freeze the THC when the machine is in corner slowdown or slowdown for small holes. For example,"freeze THC when feed rate goes below 70% of the programmed feed rate" Also there might be an option to freeze it a certain distance from the end of a cut. All of that will help with diving.
Dustan
Post by Dustan »
I have a Fastcut 4x8 icon table with a water bed a thermal dynamics cutmaster A60 I draw with turbo cad,Corel Drawx4,Sheetcam and mach3 everything but corel came with my table and alot of the settings in sheetcame and mach are beyond me so far except the basics :|
Post by Dennis »
Dustan , I have the same table with no problems, you must have your settings messed up.
Dustan
Post by Dustan »
Dennis wrote:Dustan , I have the same table with no problems, you must have your settings messed up.
I really dont know how and where to set those kinds of settings any help would be awesome thanks
WSS
Post by WSS »
Dustan, here is a link to a fastcut forum on cnczone:
http://www.cnczone.com/forums/fastcut_cnc/
Here is a link to builds by guys using simalar configurations that the icon uses ie. sheetcam, mach3, etc.. There is a lot of knowledge here.
http://www.cnczone.com/forums/plasma_ed ... oject_log/
WSS
Post by Dennis »
How are you grounding you work..
