Have new plasmacam with DesignEdge software, cannot get torch to fire
Cfhaddox
Post by Cfhaddox »
I have a hyperthermia 65 with machine interface cable with voltage divider board, I have also purchased cable from hypertherm to connect table to cutter. Have set 21.1:1 instead of factory 50:1. My issue is I cannot get my plasma to fire when I try to cut, any suggestions out there. I have auto height control
Re: Have new plasmacam with DesignEdge software, cannot get torch to fire
Do you see an error on your Hypertherm LCD when trying to fire. Something like 0-20 or 0-52 etc
rdj357
Post by rdj357 »
Are you using a hand torch or machine torch? The machine interface is designed only to work with the machine torch - it will not control the trigger circuit for the hand torch.
If you are using the hand torch, you'll need to either get and switch to a machine torch or modify the wiring for the trigger circuit as shown in the video manual (splice inline with the purple trigger wire and zip tie the trigger on).
Robert Johnson
PlasmaCAM GURU & Instructor
