THC drives Z opposite, Keyboard drives it normal
dkerr
Post by dkerr »
This is a new Proma SD Compact install on a previously working 4x4 table. Hypertherm xp30. Registered MAch3 and Sheetcam
After finally getting it to respond to the test mode, it works in reverse of what it should (I believe)
When the UP arrow lights, the Z motor goes down, when Down arrow lights, the head goes up. From the keyboard wt works normally.
Thoughts,
thanks in advance
Don
Re: THC drives Z opposite, Keyboard drives it normal
If the keyboard is working as it should you have the proma up/down signals reversed going into the BOB (in ports and pins input).
Look on the diagnostic page there is a indicator for the up/down there also.
dkerr
Post by dkerr »
Thanks for the info.....I found an easier, probably more proper fix. The proma SD has a menu system. The last item in the menu (after holding down the up and down buttons) is POL (polarity). Switching it to -1 from +1 switched the output of the THC, leaving the KB output untouched.
thanks a bunch for the alternate info....I did see the pin assignment in the diagnostic page as another route.
Don
Return to “Mach3 & Mach4 CNC”
