Hi, first time poster long time lurker, getting ready to jump into CNC plasma. Question I have is with compressor and shop lay out.
From where I have my compressor to where my table will be in the shop I am going to have about a 100' run of piping. I have an old compressor tank where the pump and motor blew. I was thinking about running the line from the main compressor into the spare tank (which will sit next to my table & next to my plasma machine) then out of the spare tank to my drier then to the cutter. My hope is between catching most of the moisture in the primary tank, then a second catch in the secondary tank then the drier I am hoping to eliminate almost all the moisture in the system plus avoid any lag in volume over that long of a pipe run.
Am I over thinking this whole thing as an obvious newbie, which I have a tendency to do! If I didn't already have the spare tank I probably wouldn't give it as much thought.
Compressor pony tank question
Re: Compressor pony tank question
It's not a bad idea at all. It would help to trap more moisture which is always a good thing and lots of air volume!
Good plan
- SegoMan DeSigns
Are you guys running an automatic tank drain? Set it and forget it:
https://www.ebay.com/sch/i.html?_from=R ... n&_sacat=0
Thanks for the backup, and I'm sure I'll be asking more questions!
I've got one of these on order. Did you just plug it straight into mains power or did you wire it in to the compressor motor wiring?SegoMan DeSigns wrote: ↑Thu Feb 07, 2019 12:23 pm Are you guys running an automatic tank drain? Set it and forget it:
- SegoMan DeSigns
I have it on an illuminated wall switch so I can flip it off at night. first thing in the am I trip it a couple of times to purge the condensation then leave it on. The timer takes over from there, I am in a dry climate and have it set at 45 minute cycles with an on time of about 5 seconds. I plumbed the drain outside of the building. It Scares the crap out of wondering animals
Pic of the 20HP / 3 phase AC the switch is tied into line lugs at the mag switch :
