X axis moves 1/2 mm right when torch fires
Lonesome
Post by Lonesome »
Every time the torch fires the x axis moves to the right about 1/2 mm. Therefore making sign off balance. Using Mach 3 and sheet cam. Any help is appreciated.
cuttinparts
Re: X axis moves 1/2 mm right when torch fires
Post by cuttinparts »
What plasma cutter are you using?
Curious if it has a high frequency start that's causing the issue.
