torch stopping in middle of cuts
hey everyone I got a BladeRunner CandCNC esp 11-A. I am running CommandCNC no limits but I am having issues with it stopping/jamming torch head on metal while in middle of cutting. which is making it very time consuming when trying to burn out a piece. Does anyone have advise that may cure this issue. Thanks in advance
Re: torch stopping in middle of cuts
Sounds like your torch height controller may not be configured properly or not functioning properly. To determine if this is the issue disable the THC and do a test cut and see if the problem goes away and we can go from there.
It only stops if it loses ARC OK (assuming its not faulting and turning off the drives) The torch dives to try and lower a voltage increase.
You will get more specific help on the CandCNC Support forum.
