Cleaning Sign
Cleaning Sign
Layered 3d sign. Thanks Ben de Lappe for the conversion! Great work again! (Not sure why the one pic turned 90?)
- lockeyone
Re: Cleaning Sign
Super nice, good work.
Table 4'x4', BladeRunner EtherCut 620 LINUX w/CommandCNC
Hypertherm 65 CPC/RS485 Machine torch 2016
BobCad router 50"x50" MACH3 2kw spindle 2003
Shoptask Eldorado cnc MACH3, 1999
Epilog Mini 24 60watt, 2013
Vectric Aspire CoralDraw x6 SheetCam
- ben de lappe
Re: Cleaning Sign
Dave...Speechless over this one. Awesome job...I split that graphic into 33 separate pieces for this project and you turn it into this???...Unfathomable. Excellent work!
- lockeyone
Re: Cleaning Sign
Plus you got to see your hand in this project. Wish more would do that, show the final project they received help from this site.
- steel 35
Re: Cleaning Sign
That is Nice!
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
- ben de lappe
Re: Cleaning Sign
Said a mouthful there lockeyone. I've helped my share here that didn't have it in 'em to say thanks...not why I do it though.
Dave and I go way back, truthfully he could have done the cad work but busy as he is it only makes sense for him to farm out the grubby part. Which fortunately I love.
And yes, thanks Dave for putting up the results...again, stellar.
Re: Cleaning Sign
There you go again Ben Raising the bar for the rest of us slugs trying to keep up, like the sign said "worth doing the job well"
That an understatement for your work You both deserve 2 thumbs up
- ben de lappe
Re: Cleaning Sign
Got to tell you acourtjester...a compliment like that coming from someone as smart and talented as you literally made my day. Thank you buddy.
Re: Cleaning Sign
Thanks Ben and everyone!
- Zippo
Re: Cleaning Sign
nice job
- dgeorgester
Re: Cleaning Sign
that's really nice work
Re: Cleaning Sign
That's awesome!!
- Scratch
Re: Cleaning Sign
Great job!
A couple things...
1. How did you hang the smaller pieces? Got a pic of how they're mounted?
2. The colors look awesome! Did you paint that? Is it all vinyl graphics? Use some sort of magic?
A couple things...
Re: Cleaning Sign
Thank you! Yes, Magic!
Here are a couple pics of hangers I use sometimes, like on this project. I got the idea from this site, just added some 3/16" rod on them for standoffs. I put them behind the art, then use a mini offset ratcheting screwdriver to tighten them. I don't know why the pics post at 90 degrees. Not like that on my phone. In the first pic, that is just a shadow coming off of the one side.
Re: Cleaning Sign
For the painting, I bought some water based airbrush paint, it was going to be my first airbrush job because I thought it would be the smoothest way to get the colors to blend to the next. I wasn't having much luck, the paint was drying in the nozzle and there was just too much area to cover. I switched up to my mini spray gun, with the same paint and it went really well. I put a clear coat on top of all of it when done. Pics attached of the paint brand and mini spray gun. I use this same gun whenever I am doing dyes (My dyes not shown, come from Steel F/X OF COURSE!). The 'we proudly use' piece is vinyl over steel. Everything else was white or black powder coat that I painted over.
- Scratch
Re: Cleaning Sign
Thanks for the info. I'm stealing your standoff mount design.
Re: Cleaning Sign
I like that standoff design too. How long do you make the 3/16 rod typically? 3 inches or so?
Newbie to plasma cutting.
Re: Cleaning Sign
Stand off length varies by what I'm doing. Usually just enough to get the driver in behind the piece. They work great on these trees that I do also, helps hold the branches in the position I want them.
