Hello everybody,
I recently purchased a new table 1 month ago.
Ive been spending every spare moment trying to figure all the ins and outs.
I bought the blocks for my machine so i can cut the 6x6 square tubing.
The problem im having is when i set up to cut the 6x6 tubing i start cutting and when it moves from cut to cut it goes to high and make
a terrible noise because i dont have the room to go any higher on the torch. im pretty sure its in the settings just need a little help thank you
new arclight 9600
Re: new arclight 9600
There should be a setting to reduce the lift on the Z axis between cuts. Let us know what table your using and you may get a more accurate solution
