Playing with the idea of building my own table since nobody makes a decent 2x4 that I found
How do you calculate size motors for top speed, acceleration?
For a rack/pinion setup, is there any advantage to using a helical vs straight cut? And how do you figure out how many teeth are ideal on the gear?
Was thinking of a direct drive instead of a gear reduction due to cost and it seems to work well for lots of other companies like premier, wright, plasmacam, and a few others
Working on making my own brackets for the bearings. Have one made but not crazy about having slotted holes for bearings. They keep sliding around so may switch to a single hole
Any help is appreciated.
DIY/Building CNC Plasma questions
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
Re: DIY/Building CNC Plasma questions
PM sent from here
I wrote this Plasma CNC Primer document which is part of the main documents for Linuxcnc
was written with the new plasma table builders in mind and actually answers many of your questions.
http://linuxcnc.org/docs/devel/html/pla ... revolution
So in answer to your questions:
1. I settled on 269 Oz/In Nema 23's but upgraded to small Nema 34's for convenience as I found some cheap prebuilt 5:1 belt drive reductions for that frame size. One of the experienced builder on Linuxcnc reckons Nema 17's are the way to go.
2. I have both helical and straight gears on my machine. The helical gears are much smoother and nicer. I will never use straight gears again.
3. The ideal travel is about 15-25mm per revolution. Mine are about 30mm and work fine
3. I did a fair bit of experimenting to determine the maximum velocity and Accelleration for my machine and I built all the gantry to be lightweight.
4. Direct drive does not put stepper motors in their optimum operating parameters. You will find it is a mistake!
Reduction derives are not that hard to make if you have a lathe. ThIs thread I raised when I first started prompted me to build 3:1 reduction that bolts onto a Nema 23 mount to replace my original direct drive design.
https://forum.linuxcnc.org/30-cnc-machi ... ve?start=0
This is what I ended up with using a couple of normal ball screw bearings plus a shaft that follows the normal ball screw dimensions for bearing journals
So basically the pinion shaft is assembled in the bearings as if its a ball screw.
belt driven is not even a consideration for me
think you're a bit wrong there, I've had no problems with belts (HTD 5mm, steel wire reinforced).
Its where you put them and how you plan your design.
What I run is very similar to this,
https://www.picclickimg.com/00/s/NTI1WD ... x2-_57.jpg
with belts in place of the rack on the outside of the machine, works fine + its cheap to replace anything on my table, not a worry. I think I'd be more reluctant using hwin rails with grinding dust
a 2x4 table is a tiny table,
each to their own YMMV
