Wedding gift.
Welder Kenny
Wedding gift.
Post by Welder Kenny »
Well guys and gals, Made a wedding gift for some good friends of ours, hope they enjoy it. any thoughts on a better way to make this..
Scratch
Re: Wedding gift.
Post by Scratch »
Looks great, I'm sure they'll love it!
Re: Wedding gift.
look very nice when you do a great job no room for improvements
Squatchemup
Re: Wedding gift.
Post by Squatchemup »
would you happen to have a blank template on this great job !!!
Re: Wedding gift.
Here is something similar I just drew up. You can change the fonts and lettering to suit your needs.
Name Plate.dxf image.jpg (65.4 KiB) Viewed 1097 times
Name Plate.dxf
(141.68 KiB) Downloaded 62 times
Re: Wedding gift.
Squatchemup wrote: Tue Oct 12, 2021 8:44 pm would you happen to have a blank template on this great job !!!
Zach - if you are looking for a simple method to curve your text and don't want to spend all the time to learn Inkscape, then I would suggest LightBurn as an alternative. You just type your text using any font you have installed on your computer, then grab the handle (blue dot) and move up or down to curve your text. You can then export as dxf and import to what ever vector editor you are using. The one-time cost to purchase LightBurn is $60. You can download the full version for a free 30 day trial to try it out. I have been using it for about 3 years now and it works great for some of the things I do.
https://lightburnsoftware.com/pages/tri ... re-you-buy
Squatchemup
Re: Wedding gift.
i will gladly try this, thank you so much for the help and suggestions anything is appreciated, currently I'm using fusion 360 sometimes i struggle
Re: Wedding gift.
If you are using Fusion 360, then you can break your circle opposite of where you want to place your text when you fit to curved path.
Re: Wedding gift.
Zach - Fusion 360 does not offer the option to fit your text "on-path". So you can put it either above or below the circle. You will need to be creative and size your circles so that the curved text matches the actual "on-path" diameter for your application.
Re: Wedding gift.
Or you can us the "Scale" tool to scale the size up or down so that your text matches the on-path circle you need.
Re: Wedding gift.
Squatchemup I would suggest staying with one software package until you have the big picture clear in your mind. Fusion 360 is a good start and many here use it for their projects. The thing with software is they may all do similar functions but call them by a different name or different methods. Jumping around between softwares can cause confusion. Once you learn and are comfortable with a package and want to look around it becomes easier to learn the different function/methods. Most here have different packages they use, some are easy doing a function to then transfer to another for finishing. It has been shown the file format can be slightly different when moving to generate a G-code. To point this out here is a program shown to me by a member (rdj357) for aiding in separating out sections of a downloaded drawing/image. Then transferring to another program to complete the project.
Re: Wedding gift.
I agree with Tom that it is a good idea to become pretty familiar with a single program before spreading yourself too thin. You mentioned that you are using Fusion 360, so I offered some information on creating curved text with that program. It is a little bit more complicated than LightBurn, so I first suggested using LightBurn to curve your text. It is always good to know your options, and then decide which one will be easiest for you to reach your end result.
Re: Wedding gift.
acourtjester wrote: Thu Oct 14, 2021 10:11 am Squatchemup I would suggest staying with one software package until you have the big picture clear in your mind. Fusion 360 is a good start and many here use it for their projects. The thing with software is they may all do similar functions but call them by a different name or different methods. Jumping around between softwares can cause confusion. Once you learn and are comfortable with a package and want to look around it becomes easier to learn the different function/methods. Most here have different packages they use, some are easy doing a function to then transfer to another for finishing. It has been shown the file format can be slightly different when moving to generate a G-code. To point this out here is a program shown to me by a member (rdj357) for aiding in separating out sections of a downloaded drawing/image. Then transferring to another program to complete the project.
That is a great video by Robert! He uses two different programs here, and if I remember correctly one of them is VinylMaster Cut - which I downloaded and started to learn back when I first saw his video. Lots of different ways to do things, and all of them very interesting!
