Need SheetCam Post Processor for Starfire controller
MMC
Post by MMC »
I have the Baileigh cnc plasma and I have a problem with Starfire Controller SF-2300S-QG it doesn't read the g-code from sheetcam then I need a custom post processor for the starfire controller. Can anyone help me to resolve this issue?
Les Newell
Re: Need SheetCam Post Processor for Starfire controller
Post by Les Newell »
Here is a post. To install this post, op the attachment and save the contents to to any convenient folder on your computer. Run SheetCam and go to Options->machine->post processor. Click on the 'Import post' button. Using the box that appears, navigate to your post and open it. Go back to Options->machine->post processor and make sure your post is selected.
Baileigh Starfire.zip
(1010 Bytes) Downloaded 107 times
MMC
Post by MMC »
Many thanks for your respond, I used your document but unfortunately the g code generated doesn't work correctly. Please find in attach the work generated with the Baileigh Starfire post in sheetcam and you can compare it with the correct gcode generated by starcam.
Baileigh Starfire G-code.zip
(394.25 KiB) Downloaded 98 times
Return to “SheetCam”
