Part will not Load correctly
When I Import a drawing/part it will not load correctly. It’s a simple drawing of a circle with one flat edge to it. When I import it into sheet cam it ends up just showing a 6inch arc with a line connecting the ends of the arc together.
Re: Part will not Load correctly
Does the drawing use splines? SheetCam doesn't work well with splines.
Could you post a copy of the drawing here so I can take a look.
