How to get a complete cut
brandon1566
Post by brandon1566 »
My table always leaves a tab on random parts that I have to break off and grind. How do I get rid of these? I’m using Inkscape, sheet cam and Mach 3. I do not have holding tab selected.
weldguy
Re: How to get a complete cut
Post by weldguy »
Sounds like the torch is beginning to move before it has pierced the material. Try increasing your pierce delay time by 1 second and if that fixes it dial it back a little until you find the perfect pierce time. You don't want it to pierce longer than needed as it will accelerate consumable wear.
brandon1566
Thank you Weldguy I didn't think of that, I will give that a shot! i believe its set at 1 right now.
SeanP
Post by SeanP »
Best way I find is to use rules in sheetcam, you can stop it completely adding a small slowdown at the end, you may need to slow more on thicker material.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
tnbndr
Post by tnbndr »
You should also play around with lead in and lead out settings. I use perpendicular with .125 in and .125 out, that solved the tab problem for me.
Although I am going to try SeanP's path rule for the end of cut as my THC always dives at the end, turning it off should fix that.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
james.davis
Post by james.davis »
I've had that happen a couple times.I have a PlasmCam I shut it down and restarted it. I also replaced the tip.Started cutting a full line again.
Jim
