Long time back I named the tools with added info about thickness or nozzle, for some reason the added names disappeared.
This was for all save toolsets, on an old disc I found the toolset with those names
. I then set out to rename them again, this turned out to be tricky. I went to the full list of tools first and clicked on edit and made the changes (no save button there) on exit they were gone. After some finger boning I found how to do it. In either location where you can change the name info I found by back spacing to the start of the name and adding a space, then moving to the end of the original name and adding the change it worked. I'm not smart just found by accident
. Then I saved that to a new name toolset, and then save to default (extra insurance
). Now the changes are there at startup
- SheetCam tool name change 2.JPG (73.04 KiB) Viewed 597 times
