Hi folks,
I don't have my table yet however thinking about some small things to cut. Started drawing a horizontal sheet clamp to be cut out of 8mm material. Might be a good idea to alter the design a bit and cut two of the 'body' files to make it symmetric.
horizontal lifting clamp
Re: horizontal lifting clamp
something like this. 10mm spacing in between to accommodate 2 washers. Designed for a 16mm bolt to hold it together
Nice!! What program are you using for the drawings? The first dxf opened, but I couldn't get the second one to open.
Looks great and love the 3d renderings Thank you
thats strange. This one is drawn in fusion360, exported as single dxf's per part, then combined in illustrator. Ill re-upload the second one again tomorrow.
Hereby the new file. Please not I haven't cut it myself, haven't cut anything at all What tolerances do people use for the tab/slot system? I have drawn some lasercut parts, those almost always fit snug without any offset.
Hi Haye,
V2 now opens fine.
V2 now opens fine.
- cstroke
Thank you...
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
