New to the cnc plasma world from south Louisiana
Teepaco
Post by Teepaco »
Hello everyone I'm new to this forum and new to cnc plasma.
I'm not new to the CNC World, about 12 years ago I built my "CajunCutter" it's all heavy duty 4' X 6' cnc router table with 3hp water cooled spindle, 5 nema 34 steppers, w/4th axis, I'm running it on MACH 3 EtherCut on XP. Electronic purchased from CandCNC.
I'm a retired machinist with a long background in building cabinets and furniture. My shop is a 42' X 100' w/14' eves. One side is a complete cabinet shop and the other a Fab/Machine shop. The machine shop is equipped with 14" X 60" manual lathe, BridgePort clone mill, Milltronics CNC mill, 60" hydraulic sheer, 10' metal break, 5' X 10' plasma table, 2" X 72" belt sander and much more.
The main reason I join this forum is the vast amount of knowledge and its members so eager to help their fellow members.
I really really like the layout of plasmaspider's forum.
Like I said earlier I'm new to the plasma world. I just purchased a used 5X10 BurnTable with a Hypertherm Powermax 65. The first project was to build a water pan for the table with a holding tank. My thinking was that I would not be using the table on a daily basis and I didn't want to leave the water just sitting in the pan causing rust to form. I found a used 350gal chemical tote and cut it down to fit under the table. I installed a 3/4 hp swimming pool pump to transfer the water up to the pan. The tote holds 200gal and the pan holds 160gal, to help prevent rust I added 4lb of BORAX 20 Mule Team, and 3lb Sodium Nitrate. I also coated the inside of the pan with BLACK JACK Elasto-Kool 1000 Elastomeric white reflective roof coating. Oh and just for looks I dump a 8-ounce bottle TotalPond Pond Blue. My wife came in the shop as I was about to start installing the slats, she said wow, it looks like a swimming pool with the blue water on the white background.
OK I'll stop running my mouth now, but before I go I would like to thank everyone for sharing their knowledge with the rest of its members.
BurnTable 5'X10' CNC Plasma Table,Hypertherm PowerMax 65
Milltronics Partner IV CNC milling machine
Bridgeport cone manual vert.milling machine
Sumit 14x60 Engine Lathe
Miller Syncrowave 250 w/Coolmate 3 for TIG
Millermatic 251 and 210 mig welders
Re: New to the cnc plasma world from south Louisiana
Welcome! Sounds like your off to great start with all of your previous experience and this is certainly a great place to find help, ideas, and make friends. The search box should be a big help and if you can't find it just ask. Best of luck!
