cut path break apart
codymoffett29
Post by codymoffett29 »
How do you break apart cut paths specifically between 2 nodes on inkscape
Re: Need help, single cut path
Perhaps upload your files (dxf, pdf, and svg) so we can take a look and try to help you.
Re: cut path break apart
You use the node remove tool, this allows you to select 2 nodes and the space between will be removed. You select a node then hold shift key down and select the node next to it and click on remove node tool. The same process can be used to connect 2 nodes to rejoin, select one node then hold shift down and select a node next to it (blank space between) click on the add node tool.
