I recently bought a 5x10 Delusional Designs CNC plasma cutter that was in a state of disrepair and I have successfully got it to a useable condition.
So far I've made 2 custom signs for friends, a fan shroud for an LS swap, a set of house numbers, and a variety of test cut shapes.
I am not convinced my torch height controller is working correctly but I haven't messed around with it too much since my cuts come out well. Also possibly need to change my consumables due to the amount of slag and now that I have the hang of cutting I will see if this makes a difference.
Hello from Missouri!
Delusional Designs 5x10
Millermatic Welder
Lincoln MP 210
Hypertherm PM 65
Thoma Torch Height Controller
Millermatic Welder
Lincoln MP 210
Hypertherm PM 65
Re: Hello from Missouri!
Welcome to the site, sounds like your off to a good start! Check out the topics in this forum https://www.plasmaspider.com/viewforum.php?f=202 you may find them to be very helpful since your just starting out. Best of luck
Welcome aboard if your cutting that is a great start, you only need to take care of some details to be completely functional.
Here is a video on how to setup a THC which should help you check yours out.
If you have question be sure to list the software you are using and images of any problems.
