Cutting 16ga stainless, 45a shielded...
I cut 14 pieces and only a couple of them have some rust spots show up.. what would cause this?
I haven't cleaned my slats between materials, i "think" it might be from grounding maybe?
I hate to have to sub stainless work to laser and thought i'd get y'alls input.
Thanks.
Stainless and rust spots
- ROKCRLER
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
Re: Stainless and rust spots
if they are ruff texture I would say grounding arc overs. Why not clamp the work lead directly to the stainless in a place that does not affect the finished product.
- Blackslacks
Its contamination caused from your stainless coming in contact with mild steel whether its your racks or tools or whatever. When loading your table with stainless set it down gently and if you have to move it pick it up to do so. Don't slide it over your racks and scratch it. This will remove the oxide layer that protects it from the atmosphere.
- ROKCRLER
Ground is on the star bolt, I'll put the clamp on the material on the next cut to see if there's a difference...thanks AC.acourtjester wrote: ↑Fri Sep 24, 2021 4:33 pm if they are ruff texture I would say grounding arc overs. Why not clamp the work lead directly to the stainless in a place that does not affect the finished product.
We loaded and unloaded extremely carefully to not scratch.Blackslacks wrote: ↑Fri Sep 24, 2021 4:43 pm Its contamination caused from your stainless coming in contact with mild steel whether its your racks or tools or whatever. When loading your table with stainless set it down gently and if you have to move it pick it up to do so. Don't slide it over your racks and scratch it. This will remove the oxide layer that protects it from the atmosphere.
Normally I don't worry about it since I usually DA the parts, but these have to be raw.
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
Those look like arc burns to me. I agree with Tom - try connecting your work lead clamp directly to the material you are cutting. I happen to use a magnetic "ground clamp" (earth lead clamp) attached directly to the material I am cutting. This could also help minimize any marking from your clamp. Or place a scrap piece of your material on either side of the ss sheet where you are clamping. Thin copper strips may also work well.
Magnet isn't going to work on stainless. I have a magnet on my work lead as well. On stainless I clamp a pair of vise grips on a corner and stick the magnet to them.
Good point. Thanks for pointing that out.
- ROKCRLER
Update.
So it turns out all the spots came off easily with alumabright. no pitting so i dont think it was arc marks, more than likely when we wiped them down and stacked them. The second batch, we wiped down with clean rags and did not stack them and zero spots..
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
Thanks for the report back
Yes - that's good to know! Happy to hear you've solved your problem.
