One thing to remember is that the support brackets need bent as a right & left.
the larger holes in the support brackets are for plug welding to the bottom of the tray.
If the torch needs serviced there is plenty of room to rotate the plasma cutter about 90? to use the access panel.
I made mine from 11 ga P&O, over kill I think 14ga should werk fine... but 11ga was on the table & I was being lazy
