Kenworth DXF templates
Re: Finding kenworth templates
Damo85 wrote: Wed Mar 02, 2022 1:55 am
adbuch wrote: Wed Mar 02, 2022 1:51 am The original was intended to be cut as a "positive". Once you draw a box around it, everything changes and you will need to take that into account. Why don't you take a stab at it and show us what you come up with. This will provide a better learning experience for you than if I do it for you. Be sure to ask if you get stumped or have questions.
no worries i will give it a go tomorrow thanks again for the help
No problem.
Took a few minutes to try my hand at bridging some of the parts for your pit. Needs more work before it could be cut as there are still drops, mostly around the wheels but is this basically what your going for?
KWPit.cdr
Damo85
Post by Damo85 »
plasmanewbie wrote: Wed Mar 02, 2022 10:18 am Took a few minutes to try my hand at bridging some of the parts for your pit. Needs more work before it could be cut as there are still drops, mostly around the wheels but is this basically what your going for?
KWPit.cdr
Yes this is indeed what i am attempting you have done a good job
Damo85
Post by Damo85 »
This is what i cut today on some old steel sheet it's not the worst but a lot of room for improvement, i was happy with the grill :) , my side with the kenworth logo didn't cut right it maybe my file i will try again tomorrow
DieselFumes
Post by DieselFumes »
Looking really good, would love to it assembled when you have it complete!
I agree! These look nice and I can't wait to see it put together.
Damo85
Post by Damo85 »
One of the workshop apprentices put her together some of the grill on the truck fell out but these are the lessons we learn
djreiswig
Post by djreiswig »
Looks like this one might have been cut with an outside offset judging by the pierces.
Maybe you fixed that on your second try.
On the grille, maybe the kerf is too wide for the artwork. I'm not sure what gauge you are using, but a fine cut nozzle may help. Or thicken the areas around the grille to prevent burn through. Also a good idea to locate pierces near the wider parts of the cut so it doesn't weaken the already thin areas.
Nice work! As was suggested, if you are using Hypertherm with duramax torch try the FineCut consumables for a narrower kerf width and less heat into the part. The FineCuts are great for detailed work. They are intended for cutting 10 ga. and thinner steel. What thickness are you using?
djreiswig wrote: Sun Apr 03, 2022 8:44 pm Looks like this one might have been cut with an outside offset judging by the pierces.
:Like :Like :Like
Damo85
Post by Damo85 »
That was cut out of 6mm mild steel and thanks for all the advice i have learnt a lot from this project and am keen to try again
Damo85 wrote: Tue Apr 05, 2022 9:51 pm That was cut out of 6mm mild steel and thanks for all the advice i have learnt a lot from this project and am keen to try again
:Like :Like :Like
RPMD
Post by RPMD »
see if you like this one.
A_Model_KW_CUT_.dxf
A_Model_KW_CUT_toolpath.dxf
I added the dxf of file without tool paths
RPMD wrote: Tue Jul 26, 2022 1:43 pm see if you like this one.
A_Model_KW_CUT_.dxf
A_Model_KW_CUT_.dxf
This looks like a pretty awesome looking design but neither Corel or Inkscape would open it properly. Anyone having luck with this design?
I opened it with DE. It looks like the cut paths with lead-ins and rapid moves are all included. I could try to clean it up, but not sure how much to delete.
RPMD
Post by RPMD »
bump
RPMD wrote: Thu Dec 15, 2022 11:48 ambump
I think you've got your file names reversed. The one you call "A_Model_KW_CUT_.dxf" looks like cut paths (tool paths), and the newer one you call "A_Model_KW_CUT_toolpath.dxf" is the drawing file. Of course they are both in dxf format.
I opened your newest file, edited to remove crossovers, etc. - and saved as shown below.
This is a good looking file and will cut fine.
Thanks for sharing your work.
A_Model_KW.dxf
