New in AZ
Re: New in AZ
Welcome aboard! I am in Tucson, so not too far apart. What kind of table did you buy, and what software are you using to run it and for your cad/cam? Which plasma cutter are you using?
Re: New in AZ
Hello and Welcome...
And yes same ? as David
Re: New in AZ
Plasma table is an older protortch table with running mach3 and sheetcam with a thermal dynamics a60. Anyone have any recommendations for the thc?
This forum is great. I have learned so much already
Re: New in AZ
That's one I have not heard of before. Perhaps you could post some photos of your setup. I like Mach3 and am using it with my Avid CNC Pro 4848 router table. It uses Warp9 with ethernet connection. Since you have Mach3, that is a huge bonus for you as it will allow you to run Scanything to do automatic tracing of templates, parts, etc. and pull them into your computer as dxf files. I use it with my Mach3 table and the total cost is under $200 including software, camera, lamp, and cables.
https://www.sheetcam.com/Scanything/index
https://plasmaspider.com/viewtopic.php? ... ng#p197054
I have included some additional links above which may be helpful.
Re: New in AZ
Wow thats awsome! I will post up some pictures of my stuff. I have a little ways to go before everything is set up to my liking.
Re: New in AZ
We will look forward to learning more about your setup. What part of Arizona are you located in?
Re: New in AZ
Welcome to the CNC plasma world. You'll have a blast and get all the information you can ask for here from all these guys/gals.
Randy,
Marketing Data Specialist – Americas Region
Hypertherm Inc.
Hypertherm Inc.
